Legend with Continous = true and formatting of legind text
Friis
Post by Friis » Fri Oct 17, 2014 8:11 am
1) How do I get the legend to span the entire ChartRect.Height? as shown in the attached graphs, it only spans the top of the chart?
2) How do I format the legend text so that it becomes - for instance - 128,6 instead of 128,577 ??
Re: Legend with Continous = true and formatting of legind text
Post by Narcís » Fri Oct 17, 2014 8:50 am
Hi Friis,
1. What about something like this?
      tChart1.Series.Add(new ColorGrid()).FillSampleValues();
      tChart1.GetLegendRect += tChart1_GetLegendRect;
      tChart1.Legend.Symbol.Continous = true;
      tChart1.Legend.Font.Size = 14;
    void tChart1_GetLegendRect(object sender, GetLegendRectEventArgs e)
      Rectangle chartRect = this.tChart1.Chart.ChartRect;
      e.Rectangle = new Rectangle(e.Rectangle.Left, chartRect.Top, e.Rectangle.Width, chartRect.Height);
2. You can modify legend text format in the GetLegenText event, for example:
    void tChart1_GetLegendText(object sender, GetLegendTextEventArgs e)
      double tmp = Convert.ToDouble(e.Text);
      e.Text = tmp.ToString("0.000");
Friis
Post by Friis » Fri Oct 17, 2014 9:09 am
1) This does not solve the problem - try to test the code I have made below on your system - can you reproduce the problem?
2) Thank you - I will use this ;-)
            Make3DGraph();
        public void Make3DGraph()
            try
                this.tChart1.Series.Clear();
                this.tChart1.Series.RemoveAllSeries();
                this.tChart1.Dock = DockStyle.Fill;
                this.tChart1.BackColor = Color.White;
                this.tChart1.Walls.Back.Gradient.Visible = false;
                this.tChart1.Walls.Back.Color = Color.White;
                this.tChart1.Walls.Bottom.Gradient.Visible = false;
                this.tChart1.Walls.Bottom.Color = Color.White;
                this.tChart1.Panel.Gradient.Visible = false;
                this.tChart1.Panel.Color = Color.White;
                this.tChart1.Aspect.View3D = false;
                this.tChart1.Panel.Bevel.Outer = Steema.TeeChart.Drawing.BevelStyles.None;
                this.tChart1.Axes.Left.Automatic = true;
                this.tChart1.Axes.Bottom.Automatic = true;
                this.tChart1.Axes.Left.Title.Caption = "";
                this.tChart1.Axes.Bottom.Title.Caption = "";
                this.tChart1.Header.Text = "";
                this.tChart1.Header.Font.Size = 14;
                this.tChart1.Legend.VertSpacing = 0;
                this.tChart1.Legend.Symbol.Width = 100;
                this.tChart1.Legend.Transparent = false;
                this.tChart1.Legend.Symbol.DefaultPen = false;
                this.tChart1.Legend.Symbol.Continous = true;
                this.tChart1.Legend.Symbol.Pen.Color = Color.White;
                this.tChart1.Legend.Symbol.Pen.Width = 1;
                this.tChart1.Legend.DividingLines.Visible = false;
                this.tChart1.Legend.Symbol.Width = 50;
                this.tChart1.Legend.Symbol.Squared = true;
                this.tChart1.Legend.Visible = true;
                this.tChart1.Legend.Shadow.Visible = true;
                this.tChart1.Legend.Font.Size = 14;
                this.tChart1.Axes.Left.Title.Text = "Power / MW";
                this.tChart1.Axes.Left.Title.Font.Size = 14;
                this.tChart1.Axes.Bottom.Title.Text = "Q / MJ/s";
                this.tChart1.Axes.Bottom.Title.Font.Size = 14;
                Steema.TeeChart.Styles.ColorGrid ColorGridSeries1 = new Steema.TeeChart.Styles.ColorGrid(tChart1.Chart);
                this.tChart1.Series.Add(ColorGridSeries1);
                ColorGridSeries1.Pen.Visible = false;
                ColorGridSeries1.Title = "surface1";
                ColorGridSeries1.UseColorRange = false;
                ColorGridSeries1.UsePalette = true;
                ColorGridSeries1.IrregularGrid = true;
                ColorGridSeries1.CenteredPoints = true;
                for (double x = 0; x < 10; x += 0.1) // = 10 rows
                    for (double z = 0; z < 10; z += 0.1) // = 10 columns
                        ColorGridSeries1.Add(x, x*z, z);
                Color[] ColorPalette = new Color[100];
                double[] ColorSteps;
                ColorPalette = SetColorPalette(1, out ColorSteps);
                for (int i = 0; i < ColorPalette.Length; i++)
                    ColorGridSeries1.AddPalette(ColorSteps[i], ColorPalette[i]);
            catch (Exception ex)
                MessageBox.Show(ex.Message);
  private Color[] SetColorPalette(byte Index, out double[] ColorSteps)
            double max;
            double min;
            ColorSteps = new double[100];
            ColorSteps[0] = 0;
            ColorPalette[0] = Color.White;
            for (int i = 1; i < 100; i++)
                ColorPalette[i] = CoolColorCode(i);
            for (int i = 1; i < ColorPalette.Length; i++)
                ColorSteps[i] = i;
            return ColorPalette;
  private void tChart1_GetLegendRect(object sender, Steema.TeeChart.GetLegendRectEventArgs e)
  private Color CoolColorCode(double ColorValue)
      ColorValue = 100 - ColorValue;
      if (ColorValue < 0)
          ColorValue = 0;
      else if (ColorValue > 100)
          ColorValue = 100;
      if (ColorValue < 25)
          return Color.FromArgb(255, Convert.ToInt16(ColorValue / 25 * 255), 0);
      else if (ColorValue < 50)
          return Color.FromArgb(Convert.ToInt16(255 - ((ColorValue - 25) / 25 * 255)), 255, 0);
      else if (ColorValue < 75)
          return Color.FromArgb(0, 255, Convert.ToInt16((ColorValue - 50) / 25 * 255));
          return Color.FromArgb(0, Convert.ToInt16(255 - Math.Round((ColorValue - 75) / 25 * 255)), 255);
Friis
Post by Friis » Fri Oct 17, 2014 9:21 am
1) Perhaps I'm not explaining the problem well enough. The blue squared symbol with a value of 15.175 in the attached image "unknown.jpeg" - I would like to have that moved down to the very bottom and the red squared symbol with a value of 128.577 to stay at the top. In that way do make the legend values show a larger range of values and colors
Post by Narcís » Fri Oct 17, 2014 9:56 am
Hi Friis,
1. This highly depends on the chart size. Another variable you can throw into the mix is Legend.VertSpacing:
this.tChart1.Legend.VertSpacing = 10;
You can make those values relative to the chart height.
Friis
Post by Friis » Fri Oct 17, 2014 10:40 am
Hi Narcis,
OK, vertspacing makes it look a little better...
But, for instance, in the attached image "unknown.jpeg" there are 10 symbols ranging from 0 to 128.577 - isn't it possible to increase this number to a larger number so that you accomplish a smoother gradient and larger gradient?
for instance, in the attached image "untitled.jpg" the legend is very smooth and there are an "unlimited" amounts of symbols ??
Post by Narcís » Fri Oct 17, 2014 11:12 am
Hi Friis,
You'd better use LegendPalette tool for that. You'll find an example at "All Features\Welcome !\Tools\Legend Palette" in the features demo available at TeeChart's program group. This applied to your example:
      //this.tChart1.Axes.Left.Title.Font.Size = 14;
      //this.tChart1.Axes.Bottom.Title.Font.Size = 14;
          ColorGridSeries1.Add(x, x * z, z);
      legendPalette1 = new LegendPalette(tChart1.Chart);
      legendPalette1.Series = ColorGridSeries1;
      tChart1.GetAxesChartRect += tChart1_GetAxesChartRect;
      tChart1.Panel.MarginUnits = PanelMarginUnits.Pixels;
      tChart1.Panel.MarginRight = legendPalette1.Width + 10;
    private Steema.TeeChart.Tools.LegendPalette legendPalette1;
    void tChart1_GetAxesChartRect(object sender, GetAxesChartRectEventArgs e)
      legendPalette1.PositionUnits = PositionUnits.Pixels;
      legendPalette1.Top = e.AxesChartRect.Top;
      legendPalette1.Left = e.AxesChartRect.Right + 5;
      legendPalette1.Height = e.AxesChartRect.Height;
      ColorSteps[0] = 0;
        ColorSteps[i] = i;
      if (ColorValue < 0)
        ColorValue = 0;
        ColorValue = 100;
Friis
Post by Friis » Fri Oct 17, 2014 12:28 pm
That looks MUCH better - Thank you ;-)
However, if I set the
legendPalette1.Transparent = false;
this looks strange - the font at the legend palette looks bold ??
LegendPaletteOK but not transparent.png (8.08 KiB) Viewed 20084 times
Post by Narcís » Fri Oct 17, 2014 1:56 pm
Hi Friis,
This looks like a bug to me. I have added it (ID971) to the bug list to be fixed for future releases.
Friis
Post by Friis » Sun Oct 26, 2014 7:53 pm
Hi Again,
How do I add a title to the legendPalette?
The following code does not work?
legendPalette1.title.text = "sasasf";
and
legendPalette1.chart.header.text = "dsf";
just adds a title to the chart itself ?
Post by Christopher » Mon Oct 27, 2014 9:33 am
Narcís wrote:This looks like a bug to me. I have added it (ID971) to the bug list to be fixed for future releases.
Yes; in the meantime, a simple workaround is this:
      Steema.TeeChart.Tools.LegendPalette legendPalette1 = new LegendPalette(tChart1.Chart);
      legendPalette1.Series = tChart1[0];
      legendPalette1.Axes.Chart.Graphics3D.TextRenderingHint = System.Drawing.Text.TextRenderingHint.SystemDefault;
      legendPalette1.Transparent = true;
Post by Christopher » Mon Oct 27, 2014 9:38 am
Friis wrote:just adds a title to the chart itself ?
Try:
      legendPalette1.Axes.Chart.Header.Visible = true;
      legendPalette1.Axes.Chart.Header.Text = "asasas";
Friis
Post by Friis » Mon Oct 27, 2014 9:47 am
Just implemented both of the solutions you have presented here - it works fantastic both of them - thank you ;-)
