Polar Series
dpatch
Polar Series
Post by dpatch » Thu Jul 17, 2014 12:52 pm
I am trying to create a chart that is sort of a cross between a polar plot and a color grid. Is this possible?
It would look like this...
It was created from a TColorGridSeries that Looks like this...
Re: Polar Series
Post by Narcís » Thu Jul 17, 2014 1:08 pm
Hi dpatch,
Sure! There's a specific series for that, the PolarGrid series? You can find an example at All Features\Welcome!\Chart Styles\Extended\Polar Grid.
dpatch
Re: Polar Series
Post by dpatch » Thu Jul 17, 2014 4:42 pm
Thanks for the quick response!
I am looking at it now. Is there a way to leave the center empty/transparent (as shown above), or even display a BMP in it? I do not want the inside pixels so close together. Thanks.
Re: Polar Series
Post by Narcís » Fri Jul 18, 2014 8:13 am
Hi dpatch,
Casually, this is the same we discussed here a couple of days ago. PolarGrid series also has DrawZone method. However, it's also affected by ID850. Please feel free to sign up at bugzilla and add yourself to the CC List to receive bug update notifications.
jens.mertelmeyer
Re: Polar Series
Post by jens.mertelmeyer » Fri Jul 18, 2014 9:13 am
If you're using a PolarGridSeries, can't you just not fill the inner cells? That would certainly make some Kind of a "hole" in there.
Also, placing something like a Bitmap in the centre of the polar diagram sounds appealing. Currently, I would not know how to best place some VCL component like a TPanel or TImage there so that it won't overlap with the diagram and only "fills" the hole.
Re: Polar Series
Post by Narcís » Fri Jul 18, 2014 9:26 am
Hello Jens,
Thanks for your contribution.
jens.mertelmeyer wrote:If you're using a PolarGridSeries, can't you just not fill the inner cells? That would certainly make some Kind of a "hole" in there.
Yes, you are right. You could set those cells to null not to be painted, for example:
var Sector, Track : Integer;
    tmp     : TChartValue;
    index   : Integer;
  with Series1 do
    Clear;
    CircleLabels:=True;
    RadiusIncrement:=1;
    NumSectors:=15;
    NumTracks:=10;
    BeginUpdate;
    for Sector:=0 to NumSectors-1 do
        for Track:=0 to NumTracks-1 do
          tmp:=0.5*Sqr(Cos(Sector/(NumSectors*0.2)))+
                   Sqr(Cos(Track/(NumTracks*0.2)))-
                   Cos(Track/(NumTracks*0.5));
          index:=AddCell(Sector,Track,tmp);
          if Track < 5 then
            SetNull(index);
    EndUpdate;
    AngleIncrement:=360/NumSectors;
jens.mertelmeyer wrote:Also, placing something like a Bitmap in the centre of the polar diagram sounds appealing. Currently, I would not know how to best place some VCL component like a TPanel or TImage there so that it won't overlap with the diagram and only "fills" the hole.
It might be easier drawing an image in the chart canvas using its Draw or StretchDraw methods. The most difficult part would be calculating the exact image size and location.
dpatch
Re: Polar Series
Post by dpatch » Fri Jul 18, 2014 2:32 pm
I don't seem to be able to find the TPolarGridSeries to drop it on the form. I see it in the User Guide but can't find it in TCharts. Can you help? Thanks!
Re: Polar Series
Post by Narcís » Fri Jul 18, 2014 2:37 pm
Hi dpatch,
At design-time, using the chart editor (double-click on a TChart component) you can find it at Series > Add > 3D > Polar Grid, scrolling down if necessary. At run-time you can find it at the TeePolarGrid class.
dpatch
Re: Polar Series
Post by dpatch » Fri Jul 18, 2014 7:12 pm
OK, I got this working. Is there a way to speed things up? Sort of like setting IrregularGrid in TColorGridSeries. Everything draws REALLY slow.
Re: Polar Series
Post by Sandra » Tue Jul 22, 2014 9:38 am
Hello dpatch,
Sorry for the delay. I think can be useful for you take a look in real time article where you can see different techniques to increase speed of your Chart.
Hoping it will help otherwise, don't hesitate to let me know.
Thanks in advance,
dpatch
Re: Polar Series
Post by dpatch » Mon Aug 04, 2014 11:22 pm
Sandra,
I truely appreciate you reply. I have read the documents regarding how to speed up the plotting and honestly they are of little help. These are the same documents that you have referenced for years. If you put a lot of data into this type of plot you will quickly see my point. I think you can easily generate an image like the one I posted and tell me if you understand my issue. If not, I can supply you with a sample that will make my point.
Thanks in advance,
dave
Re: Polar Series
Post by Yeray » Wed Aug 06, 2014 7:46 am
Hi Dave,
I've made a simple example and it seems to work fast for me here.
uses TeePolarGrid;
var index   : Integer;
  Chart1.Align:=alClient;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
  with Chart1.AddSeries(TPolarGridSeries) do
    FillSampleValues(24);
    for index:=0 to Count-1 do
      if YValue[index] < 10 then
        ValueColor[index]:=clBlack;
I've also tried incrementing the number of values (ie FillSampleValues(24) ending in 10.000 cells) and it still looks fast for me here.
