Fail at printing preview.
Petr
Post by Petr » Thu Mar 27, 2014 3:47 pm
Hi, there is problem in TeeChart Print Preview dialog. there is a Margin Units box, with items percent and 1/100 inch( by default ). If youl you'll try to change it to recent and back appears exception ( "A generic error occurred in GDI+." ). It looks like a bug.
Secondary i'd like to ask is there any way to avoid Generating Preview box, that blinks everytime i try to zoom preview size|?
Re: Fail at printing preview.
Post by Christopher » Fri Mar 28, 2014 12:50 pm
Petr wrote:Hi, there is problem in TeeChart Print Preview dialog. there is a Margin Units box, with items percent and 1/100 inch( by default ). If youl you'll try to change it to recent and back appears exception ( "A generic error occurred in GDI+." ). It looks like a bug.
This seems to work okay here using the following code:
    Surface series;
      series = new Surface(tChart1.Chart);
      series.FillSampleValues();
      series.UseColorRange = false;
      series.UsePalette = true;
      series.PaletteStyle = PaletteStyles.Strong;
      tChart1.Printer.Preview();
Clicking on any of the margin comboboxes doesn't seem to produce an error.
Petr wrote:Secondary i'd like to ask is there any way to avoid Generating Preview box, that blinks everytime i try to zoom preview size|?
I'm afraid not.
Petr
Post by Petr » Mon Jul 07, 2014 2:33 pm
Hi, after quiete long time i got this problem again. I attached simple project that demonstrates it.
PrintProblem.rar
(20.14 KiB) Downloaded 689 times
Post by Christopher » Tue Jul 08, 2014 8:26 am
Petr,
Petr wrote:Hi, after quiete long time i got this problem again. I attached simple project that demonstrates it.
I've been able to reproduce this problem here, and I think this problem could be resolved with a code change in your code:
      m_PrintRect = new Rectangle( ev.MarginBounds.X, ev.MarginBounds.Y + (int)TitleSize.Height + marginFromTitle + 6 * (int)printFont.GetHeight() + 15, ev.MarginBounds.Width, (int)( ev.MarginBounds.Height * 0.3 ) );
      //ev.Graphics.DrawImage( tChart1.Bitmap, ev.MarginBounds.X, ev.MarginBounds.Y + (int)TitleSize.Height + marginFromTitle + 6 * (int)printFont.GetHeight() + 15, ev.MarginBounds.Width, 300 );
      //ev.Graphics.DrawImage( tChart1.Bitmap, m_PrintRect );
      AdjustRectangle(ref m_PrintRect);
      System.Drawing.Imaging.Metafile m = tChart1.Chart.Metafile( tChart1.Chart, m_PrintRect.Width, m_PrintRect.Height );
	private void AdjustRectangle(ref Rectangle rect)
      int top = rect.Top;
      int left = rect.Left;
      int width = rect.Width;
      int height = rect.Height;
      if (width < 0 && left + width >= 0)
        rect.X += width;
        rect.Width = Math.Abs(width);
      if (height < 0 && top + height >= 0)
        rect.Y += height;
        rect.Height = Math.Abs(height);
does that resolve the issue?
Petr
Post by Petr » Tue Jul 08, 2014 12:31 pm
Yes, thank you, that works.
