I am using the latest 2014 TeeChart under XE6 and Windows 8.1 Attached you may find a sample application that creates a metafile and assigns it in a TImage. You can see that at the right and bottom of the created metafile appears something like a border.
Issue with TeeCreatMetafile
- Unit1.zip
- (56.72 KiB) Downloaded 603 times
Re: Issue with TeeCreatMetafile
This sounds to be the same here:
http://www.teechart.net/support/viewtop ... =3&t=14851
In your case, these could be a workaround for you:
var m: tmetafile;
oldColor: TColor;
oldColor:=Self.Color;
Self.Color:=clWhite;
m := Chart5.TeeCreateMetafile(false,
Rect(0, 0, Round(Image1.Width), Round(Image1.Height)));
Image1.Picture.Assign(m);
m.Free;
Self.Color:=oldColor;
Hello Yeray,
Thank you for your reply, indeed the code you mentioned fixes the issue but before I add so many lines to my projects do you have an estimate if this will be fixed shortly?
I see you've added your mail to the ticket so you can be notified when it will be closed.
I've incremented the issue priority but I'm afraid I can't tell you a date for this to be fixed.johnnix wrote:Thank you for your reply, indeed the code you mentioned fixes the issue but before I add so many lines to my projects do you have an estimate if this will be fixed shortly?
