Painting Problem?
Painting Problem?
Why is series 3 painting in series 2 in the second part of the graph, while it is painting on the top in the first part of the graph? Shouldn't it be the top series for the whole graph.
- test.zip
- (3.27 KiB) Downloaded 604 times
Re: Painting Problem?
Hi Blair,
The problem is Series3 has less points than Series1 and Series2. It should have the same number of points and same X values for stacking to work fine with all series. Series3 has a gap between 1st December 2013 until 15th December 2013. Adding data (zero values) for Series3 within this range, as shown in the code snippet below, solves the problem.
uses VCLTee.TeeStore;
var
i: Integer;
LoadChartfromFile(Chart1, 'g:\temp\test.tee');
for i := 1 to 15 do
Chart1[2].AddXY(EncodeDate(2013, 12, i), 0);
Ugg any quick way to check/add all the dates in all the series?
