TChart Legend Black
Bill
TChart Legend Black
Post by Bill » Wed May 07, 2014 9:29 pm
I've just upgraded one of my projects from BCB XE to BCB EX5. It compiled ok, but when I run the program, at first the legend displays ok, but when I refresh ChartSeries, the legend turned in to a black box. I've attached two images. One is before refreshing hte series and one is after.
I'm using BCB XE5 with TChart Pro v2014.10.140220 32 bit VCL.
after refresh series
before refresh sereis
Re: TChart Legend Black
Post by Yeray » Thu May 08, 2014 7:42 am
We've identified a similar problem here. Are you using GDI?
If you can't switch to GDI+, can you please arrange a simple example project we can run as-is to reproduce the problem here, so we can try to suggest you another workaround?
Bill
Post by Bill » Tue May 13, 2014 12:07 pm
Yes, I'm using GDI+. I switched to GDI and still have the same issue.
Post by Yeray » Wed May 14, 2014 8:42 am
Hi Bill,
Bill wrote:Yes, I'm using GDI+. I switched to GDI and still have the same issue.
Can you arrange a simple example project we can run as-is to reproduce the problem here?
