PIE Chart 3d bug - depending on rotation and values
PatrikS
Post by PatrikS » Wed May 07, 2014 8:59 am
We are using TeeChart Pro v2013/14.
Everything is ok:
All is fine...
Pie ok.jpg (53.78 KiB) Viewed 5207 times
Changing the last slice value:
3d "effect is gone"
Pie not ok.jpg (48.14 KiB) Viewed 5217 times
Changing rotation fixes 3d effect:
Changing rotation fixes it
Pie ok again.jpg (55.36 KiB) Viewed 5205 times
Changing the first pie value to 0 will also remove the 3d effect.
Best regards,
Re: PIE Chart 3d bug - depending on rotation and values
Post by Yeray » Wed May 07, 2014 10:37 am
Hello Patrik,
I've reproduced this problem with the following code and TeeChart v2014.10.
uses Series;
  with Chart1.AddSeries(TPieSeries) do
    Add(174000, 'Svenska Aktier');
    Add(1409238, 'Default');
    Add(1600000, 'Kassa');
    Marks.Visible:=false;
However, the same code above seems to work fine for me here with the actual sources and also with v2014.11 SourceCode Beta, so I'd expect this to be fixed with the next maintenance release. This is what I get with them:
PatrikS
Post by PatrikS » Wed May 07, 2014 10:44 am
Excellent,
Do you have a fix I could access to now and change in our source code? This issue is stopping our ability to release with the latest TeeChart.
Best regards
Post by Yeray » Wed May 07, 2014 10:47 am
Hi Patrik,
Being a SourceCode customer gives you access to the SourceCode v2014.11 Beta installer from the client access page. However, I'm afraid this Beta hasn't been tested for all the IDEs.
PatrikS
Post by PatrikS » Thu May 08, 2014 2:04 pm
I can confirm both issues are solved in the beta.
Best regards,
