Accessing a bitmap with TBMPExportFormat
Metman
Post by Metman » Fri Apr 25, 2014 8:37 pm
I am trying to capture a bitmap of a chart. I don't want to save it, I just need a bitmap to use in a image component, where I am adding a number of graphs in a grid.
I use the following code but the bitmap ends up spoiled with a lot of vertical lines. If I save the bitmap it saves correctly - am I missing something here of is it just not possible to grab a bitmap like this?? I thought it was the pixelformat property but none of them make a difference.
  tmp:=TBMPExportFormat.Create;
   try
     tmp.Panel:=Chart;
     tmp.Bitmap.PixelFormat:=pf24bit;
   finally
     tmp.Free;
Bruce.
Re: Accessing a bitmap with TBMPExportFormat
Post by Yeray » Mon Apr 28, 2014 10:58 am
Hello Bruce,
Do you know a way we can reproduce the problem here?
I've tried to add a TChart and a TImage to a form and the following code, but the image I see in the TImage looks fine:
uses Series, TeeBmpOptions;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
  Chart1.AddSeries(TAreaSeries).FillSampleValues;
var tmp: TBMPExportFormat;
    tmpOp: TBMPOptions;
  tmpOp:=TBMPOptions.Create(Self);
   try
     tmp.Panel:=Chart1;
     tmp.Bitmap(tmpOp).PixelFormat:=pf24bit;
     Image1.Picture.Graphic:=tmp.Bitmap(tmpOp);
   finally
     tmp.Free;
Metman
Post by Metman » Mon Apr 28, 2014 11:18 am
Thanks for your prompt reply.
I tried your example (I never created a TBMPOptions in my code) but was unable to add
tmpOP
to
tmp.Bitmap
because it won't allow any parameters in the version of TeeChart (8) which I'm using. So I still can't access the bitmap from the TBMPExportFormat object with a load of vertical lines.
I am sure its all to do with the pixel format but as I said in my original post I have tried them all.
Bruce.
Post by Yeray » Mon Apr 28, 2014 11:52 am
Hi Bruce,
Metman wrote:I tried your example (I never created a TBMPOptions in my code) but was unable to add
tmpOP
to
tmp.Bitmap
I was with the latest version.
Now I've tried with TeeChart v8 and removing the TBMPOptions I get this in a new simple project with just a TImage and a button:
Find the project attached:
testBitmap.zip
(1.32 KiB) Downloaded 695 times
Metman
Post by Metman » Mon Apr 28, 2014 4:10 pm
OK, you win, that works fine after I remove the 'TeeGDIPlus' in the uses clause. It must be something I'm doing. I'll create a simple demo of what I'm doing and see if I can fix it.
Bruce.
Post by Yeray » Tue Apr 29, 2014 7:11 am
Hi Bruce,
Adding this to the FormCreate to activate GDIPlus:
Chart1.Canvas:=TGDIPlusCanvas.Create;
It still gives me a good bitmap with TeeChart v8:
Maybe you are doing something else that is causing the bitmap not to be correctly exported, so yes, it would be helpful if you could arrange that simple example we can run as-is to reproduce the problem here.
Metman
Post by Metman » Tue Apr 29, 2014 8:59 am
I'll try and do that demo, but you know how it is, I'm not a crack programmer and when I get a problem I can't fix, I look for help but if that doesn't work I move on and work round the problem as quickly as possible. The bitmap looked good when I saved it using the export feature in TeeChart but wouldn't copy across so you may be right the problem is not yours.
What I was trying to do was copy a bitmap of a chart as an object into a TImageENVect component (from Xequte). It worked with other bitmaps that I had extracted from other components including TGlobe and TAdvStringGrid (TMS).
Bruce.
