Zooming with a line and points series get in unsync
Odne
Post by Odne » Thu Apr 24, 2014 12:14 pm
Hi!
I have a plot with a line and several point series.
Whe I zoom in the point and the line is not synched any more, even to pints series that should be in same location is in position correctly.
Or if I zoom even further.
The points marks are the same, but they are positioned in different locations, why?
Odne
repositioning of points when zooming problem #2.PNG (28.05 KiB) Viewed 5231 times
repositioning of points when zooming problem #1.PNG (16.62 KiB) Viewed 5223 times
Odne
Re: Zooming with a line and points series get in unsync
Post by Odne » Thu Apr 24, 2014 12:16 pm
Forgot to mention that we are using version 4.1.2012.5103 TeeChart for WinForms.
Odne
Post by Christopher » Fri Apr 25, 2014 9:46 am
Odne wrote:Forgot to mention that we are using version 4.1.2012.5103 TeeChart for WinForms.
I'm using the latest publicly available version of TeeChart.NET for WinForms with this code:
      Line line = new Line(tChart1.Chart);
      Points points = new Points(tChart1.Chart);
      Random rnd = new Random();
      for (int i = 0; i < 10; i++)
        double x = rnd.NextDouble();
        double y = rnd.NextDouble();
        line.Add(x, y);
        points.Add(x, y);
Zooming on the points here does not produce the kind of effects you show. Does it at your end? If the code above doesn't reproduce the problem, could you please give me some code that does?
