TBarSeries with "double" values
Kai
Post by Kai » Fri Apr 11, 2014 12:52 pm
We are using the TeeChartStandard2014 package.
I have a TBarSeries with some "double" values. I use this sample code:
var
  i, j: Integer;
  tmpDates: array of TDateTime;
  doADoubleValue: Boolean;
   doADoubleValue := False;
   setLength(tmpDates, 2);
   for i:=0 to High(tmpDates) do
    if i mod 2 = 0 then
     tmpDates[i]:=IncDay(Today, i*2)
     tmpDates[i]:=IncDay(Today, (i*2)+1);
    for i:=0 to 1 do
      with frmChart.ChartAccounting.AddSeries(TBarSeries) as TBarSeries do
        //MultiBar:=mbStacked;
        MarksOnBar:=False;
        MarksLocation:=mlCenter;
        CustomBarWidth:=40;
        XValues.DateTime:=true;
        for j:=0 to High(tmpDates) do
          if j mod 2 = 0 then
            AddXY(tmpDates[j]+i, 25+random*75, 'S' + inttoStr(i) + ' L' + IntToStr(j));
           end
            AddXY(tmpDates[j], 25+random*75, 'S' + inttoStr(i) + ' L' + IntToStr(j));
            if not doADoubleValue then
              AddXY(tmpDates[j], 15+random*75, 'test - S' + inttoStr(i) + ' L' + IntToStr(j));
              doADoubleValue := True;
I looks like this:
So the bars with the same values are "overlayed". The same with "mbStacked".
Any idea how to fix this?
Kai
Kai
Re: TBarSeries with "double" values
Post by Kai » Mon Apr 14, 2014 1:54 pm
I solved the problem with this solution:
var
  i, j: Integer;
  myColor: TColor;
    if i mod 2 = 0 then
    for i:=0 to 1 do
        MarksOnBar:=False;
        CustomBarWidth:=40;
        myColor := Color;
          if j mod 2 = 0 then
           end
               MarksOnBar:=False;
               CustomBarWidth:=40;
               ShowInLegend := False;
               Color := myColor;
               AddXY(tmpDates[j], 15+random*75, 'test - S' + inttoStr(i) + ' L' + IntToStr(j), myColor);
I create a "new" series with the color of the "current" one. Then it works.
Post by Yeray » Mon Apr 14, 2014 1:57 pm
Hello Kai,
With your code I get this, that is slightly different to your image:
So I guess you are also modifying the bottom axis, setting a bigger range, making the bars to be drawn more close to the other bars.
On the other hand, looking at the data I see you are adding two values at the same XValue in Series1:
Is that what you desired? If so, how would you expect the Bars to be drawn?
Post by Yeray » Mon Apr 14, 2014 1:58 pm
I see you already found how to solve it. I'm glad to hear you found it! :)
Kai
Post by Kai » Mon Apr 14, 2014 2:07 pm
Hello Yeray,
we are posting at the same time :wink:
Oh sorry ... i post only the code to add the bars.
Yes i have some values with the same XValue.
so the final looks like this:
So erverthing works fine. Thanx.
