Keeping Aspect Ration: Going wrong
Raavi
Post by Raavi » Thu Apr 10, 2014 10:11 am
I have problem in keeping aspect ratio whenever the size of client changes.
The attached solution works partly and I do not know what mistake I made there...
Any help will be greatly appreciated.
TestingTeeChartScaling.zip
(43.7 KiB) Downloaded 529 times
Raavi
Re: Keeping Aspect Ration: Going wrong
Post by Raavi » Thu Apr 10, 2014 2:19 pm
Any help will be appreciated...
Post by Christopher » Thu Apr 10, 2014 3:11 pm
Hello Raavi,
As an alternative, you can use one of the Series.IsoHorizAxes or Series.IsoVertAxes, e.g.
if you use both at the same time you will get the effect that your code gets - this effect is unavoidable, I'm afraid, the isoaxes can only be for horizontal or vertical directions, not both.
Raavi
Post by Raavi » Thu Apr 10, 2014 3:27 pm
Wonderful, that worked like a charm. :D :D :D :D
Raavi
Re: Keeping Aspect Ratio: Going wrong
Post by Raavi » Fri Apr 11, 2014 9:30 am
I have one more problem, that aspect ratio is not kept when I press maximize button.
Raavi
Post by Raavi » Fri Apr 11, 2014 12:53 pm
May I know whether it is possible to set IsoHorizAxes or IsoVertAxes to a Chart than a Series?
Right now, I add series with 'IsoHorizAxes = true' to a Chart and set Chart.Dock to Dockfill.
This way does not set the IsoHorizAxes until I change the size of the Chart or Pan the Chart.
Post by Christopher » Mon Apr 14, 2014 8:23 am
Raavi wrote:I have one more problem, that aspect ratio is not kept when I press maximize button.
I've been able to reproduce this here and have added it to our bug database with id=721. I've spent some time trying to find a workaround to this problem, but unfortunately without success.
Post by Christopher » Mon Apr 14, 2014 8:25 am
Raavi wrote:May I know whether it is possible to set IsoHorizAxes or IsoVertAxes to a Chart than a Series?
No, at the moment these properties only belong to the Series class, enabling some series to render "Iso" while others render normally.
Raavi wrote:Right now, I add series with 'IsoHorizAxes = true' to a Chart and set Chart.Dock to Dockfill.
This problem is doubtless related to the id=721 bug I mentioned in my last post. Again, I'm afraid I haven't been able to find a workaround to this issue.
Raavi
Post by Raavi » Mon Apr 14, 2014 8:40 am
Good Morning,
Thank you very much indeed.
