Stacked bars
Kai
Stacked bars
Post by Kai » Tue Apr 08, 2014 2:46 pm
We are using the TeeChartStandard2014 package.
I am testing with the MultiBar mbStacked option with this sample code:
var
  i, j: Integer;
  tmpDates: array of TDateTime;
  setLength(tmpDates, 5);
  for i:=0 to High(tmpDates) do
   if i mod 2 = 0 then
    tmpDates[i]:=IncDay(Today, i*2)
    tmpDates[i]:=IncDay(Today, (i*2)+1);
  for i:=0 to 1 do
  with frmChart.ChartAccounting.AddSeries(TBarSeries) as TBarSeries do
    MultiBar:=mbStacked;
    MarksOnBar:=False;
    MarksLocation:=mlCenter;
    CustomBarWidth:=40;
    XValues.DateTime:=true;
    for j:=0 to High(tmpDates) do
      if j mod 2 = 0 then
        AddXY(tmpDates[j]+i, 25+random*75, 'S' + inttoStr(i) + ' L' + IntToStr(j));
       end
        AddXY(tmpDates[j], 25+random*75, 'S' + inttoStr(i) + ' L' + IntToStr(j));
The data i want to use for the bars are only at some points identical, so i try to use mbStacked.
But if i have some values which are unique the bars are "up in the air" :wink: .
The result looks like this.
Any Ideas what i am doing wrong?
Re: Stacked bars
Post by Yeray » Wed Apr 09, 2014 9:37 am
Hi Kai,
This happens because the stacked is based on the value indexes.
You could loop your series & values and, if the other series don't have any value at a given XValue, add a null point there. Ie:
    for j:=0 to Chart1[i].Count-1 do
      for t:=0 to Chart1.SeriesCount-1 do
        if i<>t then
          found:=false;
          for w:=0 to Chart1[t].Count-1 do
            if Chart1[i].XValue[j]=Chart1[t].XValue[w] then
              found:=true;
              break;
          if not found then
            Chart1[t].AddNullXY(Chart1[i].XValue[j], 0);
Kai
Re: Stacked bars
Post by Kai » Wed Apr 09, 2014 11:48 am
works perfect. Thank you.
