Adding a marker on a Candle chart
Barry
Post by Barry » Thu Mar 13, 2014 1:59 pm
I have a candle chart of a financial instrument over the past 10 years - what I want to do is indicate on the chart itself next to relevant candle a 'C' for a corporate action event and a 'N' for a name change event. Having read everything I can on this I cannot see how to do it. I thought perhaps adding something in the add chart part (where the '' is) would do it but it ignores anything there
if (PlotArray.Open > PlotArray.High) OR
(PlotArray.Open < PlotArray.Low) OR
(PlotArray.Close > PlotArray.High) OR
(PlotArray.Close < PlotArray.Low) OR
(PlotArray.High < PlotArray.Low) then
Tmp := Series1.AddCandle(Series1.Count, PlotArray[i].Open,
PlotArray[i].High, PlotArray[i].Low, PlotArray[i].Close, '', clRED)
PlotArray[i].High, PlotArray[i].Low, PlotArray[i].Close, '', clNavy);
Series1.Labels[tmp] := DateToStr(EncodeDate (TheYear, TheMonth, TheDay));
Tmp1 := Series2.Add(PlotArray[i].Volume, '', ClNavy);
Series2.Labels[tmp1] := DateToStr(EncodeDate (TheYear, TheMonth, TheDay));
Re: Adding a marker on a Candle chart
Post by Narcís » Fri Mar 14, 2014 12:05 pm
Hi Barry,
Barry wrote:I thought perhaps adding something in the add chart part (where the '' is) would do it but it ignores anything there
By default, Candle series don't display series marks, you should make them visible with Series1.Marks.Visible:=True;, which works fine here:
var i: Integer;
    temp: TDateTime;
  Chart1.View3D:=False;
  for i:=0 to 10 do
    temp:= Now + i;
    if (i mod 3 = 0) then
      Series1.AddOHLC(temp, random, random, random, random, 'multiple of 3', clTeeColor)
      if (i mod 2 = 0) then
        Series1.AddOHLC(temp, random, random, random, random, 'multiple of 2', clTeeColor)
        Series1.AddOHLC(temp, random, random, random, random, 'none', clTeeColor)
Barry
Post by Barry » Fri Mar 14, 2014 2:35 pm
Thanks for this, its better but not right
No matter what I put in the marks part I always get a date.
so
Tmp := Series1.AddCandle(Series1.Count, PlotArray.Open,
PlotArray.High, PlotArray.Low, PlotArray.Close, 'E', clRED)
Always displays a Date not 'E'
Thanks for your help
Post by Narcís » Fri Mar 14, 2014 2:43 pm
Hi Barry,
Try forcing marks to display text labels with Marks.Style property
  Series1.Marks.Style:=smsLabel;
If this doesn't help please attach a simple example project we can run "as-is" to reproduce the problem here.
Barry
Post by Barry » Fri Mar 14, 2014 3:00 pm
Sorry but that didn't work, it still displays a date, I will get you a simple project over the weekend as its right in the middle of a huge piece of code so I will need to work on that.
Barry
Barry
Post by Barry » Fri Mar 14, 2014 3:03 pm
Please can you also give me the options for marks.style as smsvalue works and displays a value
Barry
Post by Narcís » Fri Mar 14, 2014 3:06 pm
Hi Barry,
Those are all options available:
  TSeriesMarksStyle=( smsValue,             { 1234 }
                      smsPercent,           { 12 % }
                      smsLabel,             { Cars }
                      smsLabelPercent,      { Cars 12 % }
                      smsLabelValue,        { Cars 1234 }
                      smsLegend,            { (Legend.Style) }
                      smsPercentTotal,      { 12 % of 1234 }
                      smsLabelPercentTotal, { Cars 12 % of 1234 }
                      smsXValue,            { 1..2..3.. or 21/6/2014 }
                      smsXY,                { 123 456 }
                      smsSeriesTitle,       { Series1 }
                      smsPointIndex,        { 1..2..3... }
                      smsPercentRelative,   { 100%..90%..120%... }
                      smsLabelPercentValue  { Cars 12 % 1234 }
smsLabel is the default value.
Barry
Post by Barry » Fri Mar 14, 2014 3:47 pm
Here is a sample small bit of code that shows the problem.
There are 2 isuses
1. It shows a mark on every line, I assumed it would only show one when i=3
2. Each mark is a date
I'm expecting '3' when i=3 else nothing
unit Chartmain;
interface
uses
  SysUtils, Windows, Messages, Classes, Graphics, Controls, StrUtils,
  Forms, Dialogs, StdCtrls, ipwCore,  ipwIPPort,  ipwHTTP,
  ExtCtrls, ipscore, ipshttps, DateUtils, TeEngine, TeeProcs, Chart, Series,
  OHLChart, CandleCh, TeeTools, ComCtrls, Grids, VclTee.TeeGDIPlus;
type
  TForm1 = class(TForm)
    Chart1: TChart;
    ChartTool1: TCursorTool;
    Series1: TCandleSeries;
  private
    { Private declarations }
  public
    { Public declarations }
var
  Form1: TForm1;
type
  PriceRec = Record
    Date  : String;
    Open  : Double;
    High  : Double;
    Low   : Double;
    Close : Double;
  End;
implementation
{$R *.DFM}
procedure TForm1.FormCreate (Sender: TObject);
Var
  i                 : Integer;
  Tmp               : Integer;
  PlotArray         : Array[0..10] of PriceRec;
  // Seed the array
  for i := 0 to 10 do
    Begin
      PlotArray[i].Open := 2;
      PlotArray[i].High := 4;
      PlotArray[i].Low := 2;
      PlotArray[i].Close := 3;
    End;
  Series1.Clear;
  Series1.Active := True;
  Series1.Visible := True;
  Chart1.Title.Caption := 'Steema Marks Demo';
  Series1.Marks.Visible := True;
  Series1.Marks.Style := smslabel;
  for I := 0 to 10 Do
    Begin
      if i = 3 then
                        PlotArray[i].High, PlotArray[i].Low, PlotArray[i].Close, '3', clNavy)
      Series1.Labels[tmp] := DateToStr(EncodeDate (2014, 1, i+1));
    End;
end.
I have attached the entire sample project
SteemaTest.rar
Full rar of the project
(10.15 KiB) Downloaded 536 times
Post by Narcís » Fri Mar 14, 2014 4:19 pm
Hi Barry,
This looks like a bug to me. When there's an empty string mark nothing should be displayed instead of copying the same mark text for all points. I have added the defect to the bug list (ID639). If you sign up to bugzilla you'll be able to receive automatic status updates. Also, a workaround is adding OnGetMarkText event like this:
procedure TForm1.Series1GetMarkText(Sender: TChartSeries;
  ValueIndex: Integer; var MarkText: String);
  if Series1.Labels[ValueIndex]='' then
    MarkText:='';
That's because of you are setting them with this line:
Commenting it out solves the problem. So that your complete code would look like this:
Var
  i                 : Integer;
  // Seed the array
  for i := 0 to 10 do
    Begin
    End;
  Series1.Clear;
  //Series1.Marks.Style := smslabel;
  for I := 0 to 10 Do
    Begin
      if i = 3 then
    End;
    MarkText:='';
Barry
Post by Barry » Fri Mar 14, 2014 4:35 pm
Re the 1st point, thanks, I will track the bug,
Re the 2nd point - sorry that's not correct, If I comment that line out the dates are not displayed along the x-axis although interestingly if I do comment it out then '3' appears on the X-axis under the relevant candle.
Just to be clear on what I want
1. I want dates along the X-axis
2. I want to be able to display a Mark against the actual candle where i=3
I think perhaps from your response this was not clear
Barry
Post by Narcís » Fri Mar 14, 2014 4:42 pm
Hi Barry,
Ok, in that case I'd recommend adding X axis dates when populating series and forcing them to be displayed at the bottom axis using LabelStyle property, for example:
  Chart1.Axes.Bottom.LabelStyle:=talValue;
  for I := 0 to 10 Do
    Begin
      if i = 3 then
        Series1.AddCandle(EncodeDate (2014, 1, i+1), PlotArray[i].Open,
    End;
Barry
Post by Barry » Fri Mar 14, 2014 4:58 pm
Sorry - my understanding is that does not skip weekends properly then, am I incorrect ? That is why I have been using the tmp= method as suggested in your doc
Also I tried this (below) and there is still a mark on every bar - have I missed something ?
unit Chartmain;
interface
uses
type
    Chart1: TChart;
    procedure SeriesGetMarkText (Sender: TChartSeries;
                  valueindex: Integer; Var MarkText: String);
  private
  public
var
  Form1: TForm1;
type
  PriceRec = Record
    Date  : String;
    Open  : Double;
    High  : Double;
    Low   : Double;
    Close : Double;
  End;
implementation
{$R *.DFM}
procedure TForm1.SeriesGetMarkText (Sender: TChartSeries;
Begin
  if Series1.Labels[ValueIndex] = '' then
    MarkText := '';
End;
Var
  i                 : Integer;
//   Tmp               : Integer;
  // Seed the array
  for i := 0 to 10 do
    Begin
    End;
  Series1.Clear;
  Chart1.Axes.Bottom.LabelStyle := talValue;
  for I := 0 to 10 Do
    Begin
      if i = 3 then
    End;
end.
Post by Narcís » Mon Mar 17, 2014 9:48 am
Hi Barry,
Sorry, I didn't understand you wanted to skip weekends. In that case my recommendation would be inverting the functionality, using labels as you originally did and customizing them in the OnGetMarkText event, for example:
unit Chartmain;
interface
uses
  Forms, Dialogs, StdCtrls, ExtCtrls, DateUtils, TeEngine, TeeProcs, Chart,
  Series, OHLChart, CandleCh, TeeTools, ComCtrls, Grids, TeeGDIPlus;
type
    Chart1: TChart;
    procedure Series1GetMarkText(Sender: TChartSeries; ValueIndex: Integer;
  private
  public
var
  Form1: TForm1;
type
  PriceRec = Record
    Date  : String;
    Open  : Double;
    High  : Double;
    Low   : Double;
    Close : Double;
  End;
implementation
{$R *.DFM}
Var
  i                 : Integer;
  Tmp               : Integer;
  // Seed the array
  for i := 0 to 10 do
    Begin
    End;
  Series1.Clear;
  //Chart1.Axes.Bottom.LabelStyle:=talValue;
  for I := 0 to 10 Do
    Begin
      if i = 3 then
    End;
  if (ValueIndex=3) then
    MarkText:='3'
    MarkText:='';
end.
Barry
Post by Barry » Mon Mar 17, 2014 10:28 am
Sorry but this is now back where I started, just to make sure I cut and pasted your code and this is the result.
Pls see attached jpg
Barry
Picture showing issue
Post by Narcís » Mon Mar 17, 2014 10:32 am
Hi Barry,
Besides copying the code you need to subscribe the OnGetMarkText event in the series at design-time or at run-time like this:
  Series1.OnGetMarkText:=Series1GetMarkText;
