How does the position change at the bar?
I would like to make displace to right (or left).
Dmitry
change position at bar
Re: change position at bar
And How tp solve problem with the overlap mark?
- barjpg.jpg (25.44 KiB) Viewed 10421 times
Hello Dmitry,
First of all, many apologies for the delayed reply.
As you can see at the version info page, this property (feature request TJ71015677) was added in Build 3.0.1.001 from November 2011.
I'm sorry but I don't understand which is your requirement here. Could you please provide more detailed information? An example project or an image would be helpful.Dmitry wrote:How does the position change at the bar?
Which exact TeeChart version are you using? Latest versions include OnTop property for SeriesMarks, true by default, that solves that problem, for example:Dmitry wrote:And How tp solve problem with the overlap mark?
series1.getMarks().setOnTop(true)
