After I installed the latest VCL in Delphi XE3 and compiled en run an older program I get an error message when I open the form with a TChart on it (see attachment) When I remove the TChart the form gives no problem.
When I put a TChart again on it the problem is back again.
Can you help me?
Greetings,
Henk van den Boogaard
error with old program
- TChart-error.png (19.86 KiB) Viewed 4988 times
Re: error with old program
Hello Henk,
This is quite strange, this property should still work. You can try changing it to Chart1.Axes.Bottom.LabelsFormat.Font.Name. If the problem persists please attach a simple example project we can run "as-is" or let us know the exact steps we should follow to reproduce the problem here.
I ported the program to Delphi XE5 with a clean install ans the problem was gone.
Is it possible that in XE3 there where leftovers from a previous install?
BTW your suggestion did not solved the problem.
I now go with XE5, so no problem.
Greetings
Henk
Greetings
Henk
Hi Henk,
Yes, maybe package/units references from different versions.HenkBoog wrote:Is it possible that in XE3 there where leftovers from a previous install?
