Failed to add Marks manually
elmec
Post by elmec » Mon Dec 23, 2013 7:40 am
I want to add Marks at some index of series, but failed..
please help me!
Find the attachment for the example project!
Add mark.png (58.97 KiB) Viewed 29239 times
AddMarks.zip
(95.97 KiB) Downloaded 1069 times
Re: Failed to add Marks manually
Post by Yeray » Mon Dec 23, 2013 11:19 am
Looking at your project, you have two series, named SeriesMark and SeriesData. Only SeriesData has points:
__fastcall TForm2::TForm2(TComponent* Owner)
	: TForm(Owner)
	// Data series
	SeriesData->FillSampleValues(10);
Then, the button does this:
void __fastcall TForm2::Button1Click(TObject *Sender)
	double max = Chart1->LeftAxis->Maximum;
	// Mark sereis which is used to show some mark.
	SeriesMark->Marks->Visible = true;
	SeriesMark->Marks->Transparent = true;
	// Tried to add a mark at index of 3 .
	SeriesMark->AddXY(3, max);
	SeriesMark->Marks->Item[3]->Text->Text = "N";
So you are adding a single point to the SeriesMark series, and then accessing to the point with index=3 to set its label.
Note that, if you are going to add the point and set the label at the same time, you can just pass the label in the same AddXY call:
	SeriesMark->AddXY(3, max, "N");
	//SeriesMark->Marks->Item[3]->Text->Text = "N";
If you need to set the label in a separate instruction, you can use "Labels->Labels[0]" (0 for the first point in the series).
	SeriesMark->Labels->Labels[0]="N";
elmec
Post by elmec » Wed Dec 25, 2013 2:28 am
Thanks for your reply.
I know that the mark could be added directly by the code below,
but the grid also disapeared...
So I have tried to use the following code to modify mark manually.
But it didn't work well...
Post by Pep » Fri Dec 27, 2013 11:14 am
In the case you want to continue displaying all the axis grid lines and bottom axis labels you have to set the bottom axis style to Value :
  Chart1.Axes.Bottom.LabelStyle := talValue;
elmec wrote:So I have tried to use the following code to modify mark manually.
Here you're correct, this is a bug, you should be able to set a specific mark text but using the code above, I testing it here the mark appear without text on it.
Could you please add it to bugzilla ? Doing so you'll be identified as the creator of the issue and therefore notified about its evolution.
elmec
Post by elmec » Mon Dec 30, 2013 4:14 am
So is there any way to fix the problem...
We are going to release our software...
Post by Pep » Mon Dec 30, 2013 10:06 am
yes, a workaround would be to set the axis label style to "talValue", like :
procedure TForm1.BitBtn1Click(Sender: TObject);
var max : double;
   max := Chart1.LeftAxis.Maximum;
   Series1.AddXY(3, max);
   Series1.Labels.Labels[0]:='N';
elmec
Post by elmec » Sat Jan 18, 2014 9:58 am
Thanks for your advice.
But would you please tell us how to fix the Marks problem.
We cannt wait for the next release.
Post by Yeray » Tue Jan 21, 2014 8:28 am
elmec wrote:But would you please tell us how to fix the Marks problem.
Isn't the workaround Pep suggested valid for you? Why?
Post by Pep » Tue Jan 21, 2014 9:10 am
Hello elmec,
as you can see at the bug resolution, it was my mistake when I say you were correct about the issue. It's not a bug. As you only have added one point to the Series, to be able to set a specific mark text for that point you have to use the 0 index for the item, like :
	SeriesMark->Marks->Item[0]->Text->Text = "N";
        SeriesMark->Marks->Item[0]->Font->Size=18;
elmec
Post by elmec » Wed Jan 22, 2014 9:04 am
OK , I'd like to repeat the problem again.
---------Code-----------
	Series1->Marks->Visible = true;
	// Add 5 points to Series
	int xpoints[5] = {10, 20, 30, 40, 50};
	int y = 100;
	for (int i = 0; i < 5; i++)
		Series1->AddXY(xpoints[i], y, IntToStr(i + 1));
	Series1->Marks->Item[0]->Text->Text = "test";
But the result is as the attachment! There is no text on mark!
Post by Pep » Wed Jan 22, 2014 12:04 pm
Hello elmec,
It's strange, it's working fine here with the latest TeeChart Pro v2013.09.131217 version usign the code you posted.
Could you please check which TeeChart version appears into your About box ?
elmec
Post by elmec » Thu Jan 23, 2014 12:33 am
Hello Pep,
Find the attachment for the Teechart version and example project.
Marks.zip
(163.29 KiB) Downloaded 1026 times
teechart version.png (115.41 KiB) Viewed 28969 times
elmec
Post by elmec » Thu Jan 23, 2014 12:35 am
Hello Pep,
teechart version.png (115.41 KiB) Viewed 28996 times
Marks.zip
(163.29 KiB) Downloaded 1076 times
Post by Yeray » Fri Jan 24, 2014 12:44 pm
Since you are a source code customer, I'll send you a link to private beta version just built to the mail account you have registered in this forum.
elmec
Post by elmec » Mon Feb 10, 2014 12:27 pm
I'll try it and tell you the result.
