Please be informed that the EPS which exported from teechart version 2013 4.1.2013.05280 couldn't recognized by PhotoShop.
Attached file is the EPS file which i export from TeeChart feature demo.
Exported EPS unable recognized by PhotoShop
- tChart1.zip
- (3.08 KiB) Downloaded 830 times
Re: Exported EPS unable recognized by PhotoShop
Hello P1858011,
Thanks for your information I have added your request in bug list report with number [TF02016663]. We will try to fix it to upcoming versions of TeeChartFor.Net
Hi Sandra,
Please be informed that i need the EPS feature urgently therefore can you please let me know when you guys will release new updates.
Hello P1858011,
The time we need to fix the bugs depends of some variables such as the complexity of the problem, the number of issues with even higher priority that claims our team attention. I recommend you to be aware at this forum, our RSS news feed, twitter and facebook accounts for new release announcements and what's implemented on them.
Hi Sandra,
Have you guys started to fix this problem as right now user start to demand this feature.
If yes, when will be the next release?
Looking forward to your respond.
Hello P1858011,
I am afraid this problem isn't still solved I have increase its severity to try to fix it to upcoming versions of TeeChartFor.Net.
Hi Sandra,
Have you guys started to fix this problem. Fyi, i am at the dead line of my project and this feature is the last thing to implement. Without the feature, the system couldn't run according to expectation.
- Guru
I will look at this problem tomorrow to see if I can ascertain the problem. Can you please confirm that this happens with *all* EPS files exported by TeeChart, or does it only happens under specific circumstances?P1858011 wrote:Have you guys started to fix this problem. Fyi, i am at the dead line of my project and this feature is the last thing to implement. Without the feature, the system couldn't run according to expectation.
- Guru
Just to inform you that this defect is now fixed, as you can see here, and this fix will be included in the next maintenance release, due out shortly.Christopher wrote:I will look at this problem tomorrow to see if I can ascertain the problem. Can you please confirm that this happens with *all* EPS files exported by TeeChart, or does it only happens under specific circumstances?P1858011 wrote:Have you guys started to fix this problem. Fyi, i am at the dead line of my project and this feature is the last thing to implement. Without the feature, the system couldn't run according to expectation.
