How to change the color of some label
elmec
Post by elmec » Thu Jan 16, 2014 8:30 am
We know
Series->XLabel[i] = "Test"
could be used to change some label text.
but is there a property like
Series->XLabel->Color[i]
used to change the label text color?
Re: How to change the color of some label
Post by Yeray » Fri Jan 17, 2014 9:40 am
I'm not sure if you want to change the Mark color or the Axis label color.
Here it is an example changing both a series Mark color and an Axis label font color:
uses Series;
    ColorEachPoint:=true;
    FillSampleValues(5);
    Labels[0]:='Apples';
    Labels[1]:='Bananas';
    Labels[2]:='Lemons';
    Labels[3]:='Oranges';
    Labels[4]:='Pears';
    Marks.Item[1].Color:=clRed;
  Chart1.Draw;
  Chart1.Axes.Bottom.Items.Automatic:=false;
  Chart1.Axes.Bottom.Items[3].Format.Font.Color:=RGB(255,128,0);
elmec
Post by elmec » Fri Jan 17, 2014 11:00 am
Thank you!
Another question, How to access points by x value, not by valueindex?
Series1->Marks->Visible = true;
	// Add 5 points to Series
	int xpoints[5] = {10, 20, 30, 40, 50};
	int y = 100;
	for (int i = 0; i < 5; i++)
		Series1->AddXY(xpoints[i], y, IntToStr(i + 1));
	// How to access some point by x value, not the valueindex.
	//Just like	Series1->MarksXValue->Item[10]->Text->Text = "";
	// which works same with the code below.
	Series1->Marks->Item[0]->Text->Text = "";
Post by Yeray » Fri Jan 17, 2014 11:43 am
Difficult to say because you can have several points in a same XValue.
To find the first point with a given XValue, you can loop into the series looking for it. Something like this:
XValueToFind:=10;
valueIndex:=-1;
found:=false;
repeat
  Inc(valueIndex);
  if (valueIndex<Series1.Count) and (Series1.XValues[valueIndex]=XValueToFind) then
    found:=true;
until (found=true) or (valueIndex=Pred(Count));
