Is it possible to achieve this kind of layout as swimlanes?
richfit
Post by richfit » Thu Jan 02, 2014 3:29 am
I am using the latest version of TeeChart Pro 2013 VCL on Delphi.
If possible, only one or multi teechart can achieve this effect?
Many thanks in advance
Richfit
Re: Is it possible to achieve this kind of layout as swimlanes?
Post by Yeray » Fri Jan 03, 2014 11:13 am
Hi Richfit,
I'd suggest you to take a look at the features demo examples. They will show you how to use the majority of features you'd need to achieve a similar chart as the one in your picture.
- I'd use THorizLineSeries as the series type. It has a Pointer property you could set Visible:=true. It also has the LinePen property, which can be used to make the pen wider (LinePen.Width:=3) or dashed (LinePen.Style:=psDash)
Ref: Features Demo example at "All features\Welcome !\Chart styles\Standard\Horiz. Line"
- I'd use the TSeriesBandTool to highlight the area between two series.
Ref: Features Demo example at "All features\Welcome !\Tools\Series Band"
- Depending on the exact needs I'd use CustomAxes, SubCharts or just ColorLines to divide the chart.
Ref: Features Demo example at "All features\Welcome !\Axes\Opaque zones"
Ref: Features Demo example at "All features\Welcome !\Tools\SubCharts"
Ref: Features Demo example at "All features\Welcome !\Tools\Color Line"
- You also have several options for the square on the top. You can use a CustomLegendTool, Annotations or custom drawing techniques.
Ref: Features Demo example at "What's New ?\Welcome !\New Chart Tools\Custom Legend Tool"
Ref: Features Demo example at "All features\Welcome !\Tools\Annotation"
Ref: Features Demo example at "All features\Welcome !\3D Canvas\Shape class"
