Teechart pro with source D2010 has been successfully installed in my conputer, but XE3 failed.
A partial copy of install log is here, please help.
TeeChart Installation
VERSION: 2013
Installing...
Win32 v14 Enterprise (Delphi and C++Builder 2010 Update 5 (Database Pack)) (2010 Update 4) OK. Time: 25s
Win32 v17 Enterprise
Tee917
Cannot recompile Delphi package: Tee917.dpk
Embarcadero Delphi for Win32 compiler version 24.0
Copyright (c) 1983,2012 Embarcadero Technologies, Inc.
VCLTee.TeeConst.pas(594) Error: E2066 Missing operator or semicolon
VCLTee.TeeConst.pas(594) Error: E2052 Unterminated string
VCLTee.TeeConst.pas(1012) Error: E2052 Unterminated string
VCLTee.TeeConst.pas(594) Fatal: E2280 Unterminated conditional directive
EXCEPTION:
Compilation aborted.
Cannot install latest VCL version under XE3
- 1.png (26.03 KiB) Viewed 8190 times
Re: Cannot install latest VCL version under XE3
Hi sswang,
Could you please reinstall TeeChart sources and try again? Probably that file has been corrupted during the installation. You could keep a "clean" sources copy just in case this occurs so that you can overwrite modified sources easily.
Hi Narcís,
I found that to be a locale problem, some characters become question mark in Chinese locale such as:
TeeConst:
TeeMsg_Copyright :={$IFDEF LCL}'(C)'{$ELSE}'?{$ENDIF}+' 1995-2013 by Steema Software';
TeePolarDegreeSymbol :='?;
I have gone through the compile process and found all problem units.
Can you convert these 4 units using delphi IDE from ANSI to UTF8 for all future releases? (and send me one copy first.
unit TeeConst;
unit TeeProCo;
unit TeeFormatting;
unit FMXTee.Editor.Formatting;
TeeConst:
unit TeeConst;
unit TeeProCo;
unit TeeFormatting;
Thanks for your feedback.
This is not possible. Those units need to be in ANSI format for compatibility with pre-Delphi 2009 IDEs. TeeRecompile automatically converts them to Unicode units for the environments where it's supported.sswang wrote: Can you convert these 4 units using delphi IDE from ANSI to UTF8 for all future releases? (and send me one copy first.)
