TRectangleTool resized problem not fixed ?
elmec
Post by elmec » Wed Nov 20, 2013 5:31 am
The problem that when TChart is resized, the TRectangleTool tool can't rezied automatically
is still not fixed, even set the Align property of TChart to alClient?
Thank you.
TestTRectangleTool.zip
(76.02 KiB) Downloaded 683 times
Re: TRectangleTool resized problem not fixed ?
Post by Narcís » Wed Nov 20, 2013 9:38 am
Hi elmec,
As far as I can see in your project, the problem is that a chart with a ScrollPager tool is not being resized. I have added the defect [ID116] to the bug list.
elmec
Post by elmec » Thu Nov 21, 2013 2:02 am
The problem is exist from the last version...
And we are told that it will be fixed in the next release (201309 version)..
but as you seen, nothing changed...
If it can be reproduced at your environment..
I found no reason why TEECHART released the new version with known bugs!!!
Post by Narcís » Thu Nov 21, 2013 8:10 am
Hello elmec,
According to the project you posted, the issue you demoed in this thread, is not what we previously discusses about TRectangleTool, is it? Moreover, we provided a solution that worked. Finally, you brought the issue to us about 2 weeks ago. At that time, the version was almost closed and ready for release, just installer preparation and tests were pending. I do not think anybody at Steema Software told you there would be a fix for that issue in the upcoming maintenance release. If that's not the case, please point me to where this was told. Having said that, which part of the resolution of the issue you are not happy with?
elmec
Post by elmec » Fri Nov 22, 2013 9:12 am
Hello Narcís,
OK, I misunderstood your meaning..I am sorry..
I was just tired of debugging TeeChart...
We are very appriciating for your rapid reply for every thread we posted..
I am not complaining to the resolution..but the TEECHART.
Wang.
Post by Narcís » Fri Nov 22, 2013 9:42 am
Hello Wang,
Thanks for your feedback.
elmec wrote: I am not complaining to the resolution..but the TEECHART.
Are there any remaining concerns about this issue?
elmec
Post by elmec » Fri Nov 22, 2013 10:03 am
Hello Narcís,
It's OK.
I am looking forward the next release.
