Chart export on iOS
OceaBen
Chart export on iOS
Post by OceaBen » Wed Nov 20, 2013 8:49 am
I'm using the last version of TeeChart 2013 (posted yesterday) on Delphi XE5 for iOS application.
TChart.SaveToBitmapFile doesn't seem to be working. This function returns false:
  Chart1.SaveToBitmapFile(GetHomePath + PathDelim + 'Documents' + PathDelim + 'test.BMP');
  Result := FileExists(GetHomePath + PathDelim + 'Documents' + PathDelim + 'test.BMP');
Is there anyway to export Chart in bmp ?
Or in other format (jpeg, pdf,....)
Ben
Re: Chart export on iOS
Post by Narcís » Wed Nov 20, 2013 11:39 am
Hi Ben,
The problem is the .bmp extension as explained at StackOverflow. Changing the filename to .jpg solves the problem:
  FileName:=GetHomePath + PathDelim + 'Documents' + PathDelim + 'test.jpg';
  Chart1.SaveToBitmapFile(FileName);
For a PDF export you can do this:
uses
  FMXTee.Canvas.PDF;
var
  FileName  : String;
  Extension : String;
  Extension:='pdf';
  FileName:=GetHomePath + PathDelim + 'Documents' + PathDelim + 'test.' + Extension;
  //Chart1.SaveToBitmapFile(FileName); //use .jpg http://stackoverflow.com/questions/19482829/firemonkey-taking-and-saving-pictures
  TeeSaveToPDFFile(Chart1, FileName, Round(Chart1.Width), Round(Chart1.Height));
OceaBen
Post by OceaBen » Wed Nov 20, 2013 1:03 pm
Perfect. Thank you!
Post by Narcís » Wed Nov 20, 2013 2:00 pm
Hi OceaBen,
As an update, we have added this to the bug list [ID118] to be improved for future releases. If you sign up at our bugzilla system I can add you to the CC List to be updated about the issue's evolution.
