vcltee@Tecanvas@Tchartpen@SetVisible$qqrxo error
redgar
Post by redgar » Wed Nov 20, 2013 11:08 am
Prior to install I uninstalled the previous version and rebooted then installed the latest TeeChart 2013.09.131119 VCL/FMX for Delphi XE3 Ultimate.
All seemed to go well until I started Delphi and attempted to load up an existing project which contains some basic TeeCharts.
I received the error dialogue stating
bds.exe - Entry Point Not Found
The procedure entry point
@vcltee@Tecanvas@TChartPen@SetVisible$qqrxo could not be located in the dynamic link library Tee917.bpl
Please can you advise how to resolve this problem.
Many thanks
Rob
Re: vcltee@Tecanvas@Tchartpen@SetVisible$qqrxo error
Post by Narcís » Wed Nov 20, 2013 11:20 am
Hi rob,
This looks like the same problem as discussed here.
redgar
Post by redgar » Wed Nov 20, 2013 3:23 pm
Sorry this does not fix the problem, when I click on Install Packages I get the dialogue below.
Install Packages.gif (64.61 KiB) Viewed 5636 times
Then when I try to select the unticked checkbox against c:\Windows\system32\frxTee17.bpl
I get the dialogue message below relating to bds.exe - Entry Point Not Found
BDS.exe Entry Point Not Found.gif (20.58 KiB) Viewed 5660 times
When I click on OK I get
Cannot Load package c:\Windows\system32\frxTee17.bpl
The specified procedure could not be found.
Specified procedure cannot be found.gif (18.39 KiB) Viewed 5648 times
I am running Windows 7 Pro 64bit Delphi XE3 Ultimate with all available patches, and also running FastReports 4.15 for VCL.
Post by Narcís » Wed Nov 20, 2013 3:43 pm
This for the Fast Reports packages for TeeChart I guess. The problem might be that FastReports packages that are still using the old TeeChart versions. You could try disabling them and enabling new TeeChart packages. If that works then you should consider updating your FastReports for TeeChart components to your current TeeChart version. You could ask FastReports for packages compatible with your TeeChart version or, if you have FastReports sources, do something similar to what's explained in the QuickReport article.
