TeeChart 2013.09.131119 VCL/FMX release link error
elmec
Post by elmec » Wed Nov 20, 2013 5:01 am
I updated TeeChart from verion of 201308 to 2013.09.131119 VCL/FMX.
But then my code get the following link errors...
which is OK before updated.
The detail is that
(1) Installed 2013.09.131119 VCL/FMX without uninstalling old one.
(2) Start RAD XE4 then error arose. (Find attachment 1)
(3)Close RAD XE4, uninstall and reinstall...
(4)Start RAD XE4, the same error with (2)
(5)Ignore the errors and recompile my project, get the link errors (Find attachment 2)
attachment 2
link error.png (33.4 KiB) Viewed 14313 times
attachment 1
install error.png (60.25 KiB) Viewed 14321 times
Re: TeeChart 2013.09.131119 VCL/FMX release link error
Post by Narcís » Wed Nov 20, 2013 8:04 am
Hi elmec,
I recommend you to uninstall both versions and install new version only. If problem persists, please check that search paths in XE4 point to the latest TeeChart version. If sending error message please translate them into English so that we can get an idea of the exact problem
elmec
Post by elmec » Wed Nov 20, 2013 8:49 am
I uninstall all the versions fro XE4, and reinstall the newest version, but problem remains.
Post by Narcís » Wed Nov 20, 2013 9:03 am
Hi elmec,
Ok, thanks. Go to Component -> Install Packages and check that new TeeChart packages are enabled on the list.
elmec
Post by elmec » Thu Nov 21, 2013 1:50 am
They are enabled in the list..
Post by Narcís » Thu Nov 21, 2013 8:02 am
Hi elmec,
Did this help in any way? Do you still get same error messages?
elmec
Post by elmec » Fri Nov 22, 2013 9:15 am
Hello Narcís,
No, errors remains..
And would you pls tell us how to solve the following problem?
Post by Narcís » Fri Nov 22, 2013 9:23 am
Hi elmec,
If problems persists, please uninstall old versions and remove all its paths from:
Project -> Options -> C++ (Shared Options) -> Include Path.
Project -> Options -> C++ Compiler -> Directories and Conditionals -> Include file search path.
Tools -> Options -> Environment Options -> C++ Options -> Paths and Directories -> System Include path
Tools -> Options -> Environment Options -> C++ Options -> Paths and Directories -> User include path
Tools -> Options -> Environment Options -> C++ Options -> Paths and Directories -> Library path
Tools -> Options setting must be set for each Delphi and C++ Builder supported platform: 32-bit, 64-bit, OSX, iOS, etc.
As far as the warning messages in your last post, could you please translate them for us?
elmec
Post by elmec » Fri Nov 22, 2013 10:30 am
It's OK.
Thank you.
