ScrollPager
agalves
ScrollPager
Post by agalves » Tue Nov 19, 2013 12:04 pm
After add ScroolPager tool the panel margins in pixels doesn't work.
See attachment.
Re: ScrollPager
Post by Sandra » Wed Nov 20, 2013 9:35 am
Hello agalves,
If you wan change the Margins of Parent Chart after add ScrollPager Tool you must disable previously the CustomChartRect as do in next line:
tChart1.Chart.CustomChartRect = false;
After you have done it, you can adjust the margins as you want. Could you tell us if previous code works for you?
agalves
Re: ScrollPager
Post by agalves » Thu Nov 21, 2013 1:35 pm
Hi Sandra, thanks for your response. This code works perfectly.
Best Regards.
