How to fix the grid width by inches or pixels, not the numbers of points?
So when the Tchart resized, the grid width will be kept fixed.
How to fix grid width by inches or pixels
- Grid Width by Pixels.png (67.16 KiB) Viewed 6334 times
Re: How to fix grid width by inches or pixels
Hi elmec,
You could calculate the axis range (Maximum minus Minimum) and then divide it for the number of grid lines you'd like to get and set Increment property accordingly.
Hello Narcís,
I meant that how to fix the grid width without changing Increment
when TChart resized.
Hi elmec,
Use custom labels instead then. You'll find an example at All Features\Welcome!\Axes\Labels\Custom Labels in the features demo.
