TChart can't be cloned with Clone() Function?
elmec
Post by elmec » Thu Nov 14, 2013 11:57 am
The exception shows that "The TChart class can't be found"..
Re: TChart can't be cloned with Clone() Function?
Post by Narcís » Thu Nov 14, 2013 12:01 pm
Hi elmec,
Are you adding FMXTee.Chart unit to your project's uses section? Code below works fine for me.
uses
  FMXTee.Chart;
var Chart1,Chart2: TChart;
  Chart1:=TChart.Create(Self);
  Chart2:=(Chart1.Clone(Self) as TChart);
If the problem persists please attach a simple example project we can run "as-is" to reproduce the problem here.
elmec
Post by elmec » Thu Nov 14, 2013 12:07 pm
The example project.
CopyChart.zip
(74.6 KiB) Downloaded 599 times
Post by Narcís » Thu Nov 14, 2013 2:12 pm
Hi elmec,
C++ Builder needs to call RegisterClass befor calling Clone:
void __fastcall TForm12::btnCopyClick(TObject *Sender)
	RegisterClass(__classid(TChart));
	TChart* chartcopyed =  (TChart*)(Chart1->Clone(Chart1));
	chartcopyed->Parent = this;
	chartcopyed->Align = TAlignLayout::alClient;
If there were series on tha chart you should also use:
#pragma link "FMXTee.Series"
RegisterTeeStandardSeries();
elmec
Post by elmec » Fri Nov 15, 2013 2:22 am
After the follow code added,
The TChart gets to OK, but the series still failed to be cloned.
CopyChart.zip
(81.7 KiB) Downloaded 655 times
Post by Narcís » Fri Nov 15, 2013 9:05 am
Hi elmec,
Actually series are being cloned. What is not cloned is their data. You should manually do that using AssignValues:
	 TChart* chartcopyed =  (TChart*)(Chart1->Clone(this));
	 for (int i = 0; i < Chart1->SeriesCount(); i++) {
		 chartcopyed->Series[i]->AssignValues(Chart1->Series[i]);
		 //Code to clone series
		//CloneChartSeries(Chart1->Series)->ParentChart=chartcopyed;
elmec
Post by elmec » Fri Nov 15, 2013 9:34 am
Hello Narcís ,
It works!
Thank you so much!
BTW, is it a bug or just Tchart's behavior?
Post by Narcís » Fri Nov 15, 2013 9:58 am
Hi elmec,
elmec wrote:Hello Narcís ,
It works!
Thank you so much!
You're welcome.
This is as designed.
