About Horizontal Point Line
Re: About Horizontal Point Line
Post by Narcís » Wed Nov 13, 2013 10:12 am
Hi elmec,
elmec wrote: But please let us know if the problem has any new status.
Having signed up at Steema Software's bugzilla you'll be automatically notified in case there's any update on the issues you added.
elmec
Post by elmec » Wed Nov 13, 2013 10:27 am
Hello Narcís,
I just tried to check the "Default" of Pointer setting form,
then it seems going worked.
But even I unchecked "Default" of Pointer ,
the problem can't be reproduced... I am confused!
Anyway, would you please tell me how to set "Default" of Pointer
to TRUE by code?
Post by Narcís » Wed Nov 13, 2013 10:33 am
Hi elmec,
Default Pointer.Style is psRectangle:
Series1.Pointer.Style:=psRectangle;
The issue occurs with psSmallDot.
elmec
Post by elmec » Wed Nov 13, 2013 10:45 am
But when I using code in the example project I have attached before,
it didn't work!
Are there any other setting for the "Default" check?
Series2->Pointer->Style = psRectangle;
elmec
Post by elmec » Wed Nov 13, 2013 10:51 am
Attatch example project
Pointer.zip
(144.89 KiB) Downloaded 610 times
Pointer.zip
(144.89 KiB) Downloaded 579 times
Post by Narcís » Wed Nov 13, 2013 10:54 am
Hi elmec,
The design of this form (TeePoEdi) has changed for the upcoming version. I think the checkbox you mention does this:
    ThePointer.Color:=clTeeColor;
    ThePointer.Pen.Color:=clTeeColor;
What makes a difference in your project is setting Pointer.Pen.Color:
	Series2->Pointer->Pen->Color=clTeeColor;
elmec
Post by elmec » Wed Nov 13, 2013 11:13 am
Hello Narcís,
By adding the following two lines, it seems that the problem has been solved...
Post by Narcís » Wed Nov 13, 2013 11:15 am
Hi elmec,
Yes, as I have added in my last reply, Pointer.Pen.Color makes the difference. That only works with psRectangle though, still fails with psSmallDot.
