Having signed up at Steema Software's bugzilla you'll be automatically notified in case there's any update on the issues you added.elmec wrote: But please let us know if the problem has any new status.
About Horizontal Point Line
Re: About Horizontal Point Line
Hi elmec,
Hello Narcís,
I just tried to check the "Default" of Pointer setting form,
then it seems going worked.
But even I unchecked "Default" of Pointer ,
the problem can't be reproduced... I am confused!
Anyway, would you please tell me how to set "Default" of Pointer
to TRUE by code?
to TRUE by code?
- pointer.png (33.96 KiB) Viewed 10326 times
Hi elmec,
Default Pointer.Style is psRectangle:
The issue occurs with psSmallDot.Series1.Pointer.Style:=psRectangle;
But when I using code in the example project I have attached before,
it didn't work!
Are there any other setting for the "Default" check?
it didn't work!
Series2->Pointer->Style = psRectangle;
- default.png (28.56 KiB) Viewed 10326 times
Attatch example project
- Pointer.zip
- (144.89 KiB) Downloaded 610 times
- Pointer.zip
- (144.89 KiB) Downloaded 579 times
Hi elmec,
The design of this form (TeePoEdi) has changed for the upcoming version. I think the checkbox you mention does this:
What makes a difference in your project is setting Pointer.Pen.Color:
ThePointer.Color:=clTeeColor;
ThePointer.Pen.Color:=clTeeColor;
Series2->Pointer->Pen->Color=clTeeColor;
Hello Narcís,
By adding the following two lines, it seems that the problem has been solved...
Hi elmec,
Yes, as I have added in my last reply, Pointer.Pen.Color makes the difference. That only works with psRectangle though, still fails with psSmallDot.
