SeriesBand has SeriesIndex dependant transparency?
Whookie
Post by Whookie » Tue Nov 12, 2013 12:09 pm
When you compile (DXE4/Win32) the attched demo you can use the "Up"/"Down" buttons to raise or lower the blue series (Series4). By doing so the red SeriesBand changes its color (even though neither Color nor Transparency is touched)!
So basically what I need is a constant "color" for the SeriesBand. Because in my Chart are a lot of Series, which can be brought to front (by clicking on it), but that should not change the SeriesBands-look.
UpDownTransparency.7z
(1.75 KiB) Downloaded 509 times
Re: SeriesBand has SeriesIndex dependant transparency?
Post by Narcís » Tue Nov 12, 2013 12:37 pm
This looks like a bug to me. Could you please add it to bugzilla? Doing so you'll be identified as the creator of the issue and therefore notified about its evolution.
Whookie
Post by Whookie » Tue Nov 12, 2013 2:40 pm
ok, do I log in at bugzilla with the same credentials as here?
Post by Narcís » Tue Nov 12, 2013 3:03 pm
Hi Whookie,
No, you should sign up at bugzilla.
