About Horizontal Point Line
There is no Horizontal Point Line,
so I using the Horizontal Line, and set the Pointer as visible,
change the transparency to 100 to hide the line between pointer
to make it look like as pointer series.
But just like shown in the attachment,
when there are a lot of points ,
they are drawed overlaping each other, so cannt be shown clearly.
When I zoom in the series, it became clearly drawed.
Do you have any ideas to draw all the pointer in like some "Merge" mode?
- HorizontalPointLine.png (4.57 KiB) Viewed 23556 times
Re: About Horizontal Point Line
BTW, We are using the newest Teechart (201308) version for XE4 Firemonkey HD App.
Yes, you can do as in the All Features\Welcome\Functions\Extended\Reducing number of points example in the features demo, which uses TDownSampling function. Demo can be found at TeeChart's program group.elmec wrote: Do you have any ideas to draw all the pointer in like some "Merge" mode?
Hello Narcís,
Thanks for your advice.
Is there any other way to draw all the points clearly?
Hi elmec,
You can either set pointer style to small dots:
Or make pointers smaller:
Series1.Pointer.Style:=psSmallDot;
Series1.Pointer.VertSize:=1;
Series1.Pointer.HorizSize:=1;
The attachment I have attached was the result after
So, I tried to
but all of the points diappeared...
BTW, I am using XE4 Firemonkey HD APP.
Hi elmec,
This looks like a bug to me. Could you please add it to bugzilla? Doing so you'll be identified as the creator of the issue and therefore notified about its evolution.
Anyway, I'll attach the example project.
- Pointer.zip
- (155.4 KiB) Downloaded 880 times
I have add it to Bugzilla.
Bug 93 has been added to the database...
Thanks elmec,
That's the bug: ID93. There's a problem with the bottom axis range. Commenting out the line below points are visible.
//Chart1->BottomAxis->SetMinMax(-0.3, 0.3);
I think that's not the cause of problem..
The values are between the range I set,
why cannt I fix the range of Y axis (Bottom Axis for Horizontal Line)?
Hello Narcís ,
If you have any temporary method to fix that,
please help us!
Our software will be release at this end of month.
please help us!
Hello elmec,
If none of the options suggested works fit your needs, you could try using a Bubble series with very small radius.
Hello Narcís ,
We'll have a try of Bubble Sereis.
But please let us know if the problem has any new status.
