I have recently upgrade Teechart from a two years old version, and I have this error, in a code which runs before the upgrade.
GaugeSeriesPointer is not marked as serializable
- gaugeseriesPointer.png (30.36 KiB) Viewed 8445 times
Re: GaugeSeriesPointer is not marked as serializable
Hello wakeup,
Next code works in correct way for me:
Could you check if my code works for you?
Steema.TeeChart.Styles.Line line1;
Steema.TeeChart.Styles.GaugeSeriesPointer gauge;
line1 = new Line(tChart1.Chart);
gauge = new GaugeSeriesPointer(tChart1.Chart, line1);
line1.FillSampleValues();
line1.Pointer.Visible = true;
tChart1.Export.Template.Save(@"C:\test.tmp");
line1.GetPointerStyle += line1_GetPointerStyle;
button1.Click += button1_Click;
void line1_GetPointerStyle(CustomPoint series, GetPointerStyleEventArgs e)
gauge.Draw(line1.CalcXPos(1), line1.CalcYPos(1), Color.Red);
It runs, but try this example project
http://193.145.251.126/pnp/files/Xmutyz ... chart2.zip
Push button1, and then button2. I get the error in button 2.
Hello wakeup,
Thanks for extra information. I can reproduce this problem, I have added it in bug list report with number [id90]. We will try to fix it to upcoming versions of TeeChartfor.Net. Remember you can follow the status of the bug in this link.
On the other hand, could you tell us in which version it works fine for you?
My previous version was
TeeChartNET2010VSNET2010_4.0.2010.13053.exe
Hi wakeup,
Many thanks.
Many thanks.
