Barseries, overlapping bars
JohnA
Post by JohnA » Wed Sep 04, 2013 9:16 am
Hi.
What I would like to do is have x number of points(x-axis) with y numbers of barseries to each x-value.
In this case to points (x) 20111, 42111 and 15 barseries (y) to each.
How can I prevent the bars form overlapping?
And I also want an spacing between the points on the x-axis.
Something similar like in the After.png. But not such an big spacing.
After.png spacing is created by adding x-axis point 20112
I have uploaded an zip attachment containing Before/after
JohnA
Barseries.zip
(131.57 KiB) Downloaded 422 times
Re: Barseries, overlapping bars
Post by Narcís » Thu Sep 05, 2013 8:49 am
Hi JohnA,
Are you using MultiBar property? I recommend you to have a look at the examples at All Features\Welcome!\Chart Styles\Standard\Bar\Side All Layout in the new features demo, available at TeeChart's program group. If this doesn't help please attach a simple example project we can run "as-is" to reproduce the problem here.
JohnA
Post by JohnA » Wed Sep 25, 2013 12:59 pm
Hi.
I can not find the features demo.
It is not located under the TeeChart's program group.
thanks
Uten navn.png (7.43 KiB) Viewed 10223 times
Post by Narcís » Wed Sep 25, 2013 1:06 pm
Hi JohnA,
That's the source code version. Demos, tutorials and documentation ares only included with the binary installers to keep the source code version as small as possible. Moreover, source code customers also have access to the binary installers. We recommend to install them prior to the source code version to have access to those resources.
JohnA
Post by JohnA » Wed Sep 25, 2013 2:39 pm
Hi.
I uninstalled with source code
Installed binary
installed with source code and recompiled.
When I'm starting the new features demo I get this error.
JohnA
Post by JohnA » Wed Sep 25, 2013 2:41 pm
In case you do not understand norwegian ;)
roughly translated to "Procedure Entry Point did not exist in the dynamic link library"
Post by Narcís » Wed Sep 25, 2013 2:43 pm
Hi JohnA,
That's probably because the .bpl it was compiled with no longer exists as it was overwritten by the source code generated package. In that case you should open the demo project (Tee9New.dpr) at C:\Program Files\Steema Software\TeeChart 2013 for RAD XE4\Examples\Features, for example, and compile it with your current TeeChart version.
JohnA
Post by JohnA » Thu Sep 26, 2013 7:21 am
Hi.
I was not able to solve this with the multibar property.
I have attached an sample project demonstrating the problem.
You can se that the bars overlapping.
What I'm looking for is 2 groups of bars: 20111 and 42111 (x-values)
and a space between them
thanks
BarSeries.zip
(82.79 KiB) Downloaded 408 times
Post by Yeray » Fri Sep 27, 2013 10:47 am
Hi JohnA,
What about setting a smaller bar width percent?
    (Chart1[i] as TBarSeries).BarWidthPercent:=75;
JohnA
Post by JohnA » Tue Oct 08, 2013 8:11 am
The chart look better now :)
