I'm using a THighLowSeries component to show values of two diffrent colors. If its above a certain threshold then its one color if its below its another. The trouble is that the series does not mark the boundary when the line intersects with the horizontal threshold value correctly and the colors are out of alignment (see attachment).
Is there anything I can do to correct this?
I did try adding another THighLowSeries series and use one for above the threshold and one for below the threshold but ran into the same problem.
Bruce.
THighLowSeries problem
- Capture1.png (16.23 KiB) Viewed 11598 times
Re: THighLowSeries problem
Hi Metman,
Could you please attach a simple example project we can run "as-is" to reproduce the problem here?
I'm also getting a similar problem where the high and low values are the same the fill is not rendered from the previous point properly.
Another problem is that the fill does not render at all if the chart Renderer is set to GDI+ !!!
Sean.
Sean.
Hello everyone,
It might be that you have not set the brush for either High or Low values. Code snippet below works fine for me here using latest TeeChart 2013 release. Does this work fine for you? Can you please modify the code so that we can reproduce the problem here?
const NumPoints: Integer = 50;
var i: Integer;
Series1.HighBrush.Style:=bsSolid;
Series1.LowBrush.Style:=bsSolid;
for i:=0 to NumPoints-1 do
Series1.AddHighLow(i, NumPoints-i, i);
Thanks, setting the High & Low brush style to bsSolid has worked for me.
Still having problems with GDI+ not rendering the fill.
Sean.
Sean.
Hi Sean,
From latest maintenance release, default canvas used is GDI+. Hence, I did the example I posted with GDI+ and worked fine for me. Can you please modify the code are attach a simple example project we can run "as-is" to reproduce the problem here?Still having problems with GDI+ not rendering the fill.
Before I write a demo project perhaps you can say what I'm doing in code is actually causing the problem?
Here is the snippet that produces the screen shot I already sent you.
The parts of the graph that are above the mean are green but orange if they fall under the mean.
Let me know if you have any idea - if not I'll put together a demo.
Bruce.
const
accumulation = array[0..5] of double = (960,880,895,950,860,900);
mean = 905;
var
idx : integer;
for idx:=0 to 5 do
if accumulation[idx]>mean then
Series1.AddHighLow(idx,accumulation[idx],mean,'',clLime)
Series1.AddHighLow(idx,mean,accumulation[idx],'',clWebOrange);
Bruce.
