Problem using Lines or FastLines on Verically oriented chart
Rich
Post by Rich » Tue Dec 30, 2003 2:09 pm
This problem was posted on Dec 16 (see original post) but has had no response yet. :(
Post by Christopher » Tue Dec 30, 2003 2:38 pm
Hi Rich,
Many apologies for the delay. I've run a few simple tests with the Line and FastLine Series using XValues.Order = loNone (0) and everything seems to work as expected.
Could I possible trouble you to send me a project that I can run "as-is" to reproduce the problem here?
Many thanks.
Thank you!
http://groups.google.com
http://codenewsfast.com/
Rich
Post by Rich » Wed Jan 07, 2004 4:44 pm
I'm emailing a project to support@steema.com. If this isn't the right location, let me know. There was one piece of info I left out which is why you couldn't replicate it. If you save the chart to a .tee file, then import it again (which we're doing - it's a web app) you lose the sort on the import with TeeChart 6.
Post by Pep » Thu Jan 08, 2004 10:51 am
Hi Rich,
yes, you're correct, I'm able to reproduce the problem here importing from a .tee file. This is a bug, I've added it on our defect list and a fix for it will be considered to inclusion for the next maintenance releases.
In meantime, you need this feature urgently you can use the TeeChart Pro v5.06 with which this problem does not happens.
Josep Lluis Jorge
http://support.steema.com
