OMP
Post
by OMP » Mon Jul 01, 2013 2:41 pm
Dear,
When I add more then 25 lines in my chart which all have only 1 point, my 3D chart looks strange.
This my code:
chartToTest.Aspect.View3D = true;
for (int i = 0; i < 30; i++)
Steema.TeeChart.Styles.Line line = new Steema.TeeChart.Styles.Line(chartToTest.Chart);
line.Pointer.Visible = true;
line.Add(0, "");
Kind regards
- 3D chart.PNG (17.77 KiB) Viewed 12965 times
Post
by Sandra » Tue Jul 02, 2013 8:46 am
Hello OMP,
Using your code with latest maintenance release of TeeChartFor.Net ( Build 4.1.2013.05281):
// tChart1.Dock = DockStyle.Fill;
Steema.TeeChart.Styles.Line line = new Steema.TeeChart.Styles.Line(tChart1.Chart);
line.Add(0, "");
I have gotten next results where your problem doesn't appear.
- TestAxes.jpg (51.95 KiB) Viewed 12947 times
Could you please tell us which version of TeeChartFor.Net are you using?
OMP
Post
by OMP » Tue Jul 02, 2013 10:20 am
I have downloaded the latest version (4.1.2013.5282) and tried it again, but the issue still remains.
Post
by Sandra » Tue Jul 02, 2013 12:09 pm
Hello OMP,
Could you please send us your project because we can try to reproduce your problem here, so, using your attached code it doesn't appears for me?
OMP
Post
by OMP » Tue Jul 02, 2013 1:07 pm
When I was making the test project, I have noticed that it depends on the size of the window and the number of lines that are used.
In the test project I couldn't reproduce it with 30 lines, but when 50 lines are used, the issue is still there.
I will send the test project to support.
Post
by Narcís » Tue Jul 02, 2013 1:23 pm
I have edited your email because you posted the
Pro Support email address. You can either attach your project here or post it at
www.steema.net/upload/
OMP
Post
by OMP » Tue Jul 02, 2013 1:56 pm
I've attached the project here now. My apologies for the misunderstanding.
- TeeChartTest.zip
- (112.47 KiB) Downloaded 805 times
Post
by Sandra » Wed Jul 03, 2013 10:18 am
Hello OMP,
We consider it as an enhancement and for this reason we have added it in wish-list with number [TF02016632] to we will consider its inclusion in future maintenance releases of TeechartFor.Net.
