DLine Axis Assignment Reference issue
This is difficult to put into words, so I've included a project to demonstrate the issue.
The Left Axis is set to 50.
The Right Axis is set to 20,000.
When a DLine is created, it appears to automatically set it’s Axis reference (for use in calculating it’s position) to the Left Axis – if it’s active. If not, then it defaults to the Right Axis.
So, drawing a DLine that needs to be associated with the Left Axis is visible when the Left Axis is active. Likewise, if the Left Axis is not active but the Right Axis is, then the DLine is referenced to the Right Axis. If both DLines are required to be visible, and both Axis’s are required to be visible, then the DLine’s position that is referenced to the Right Axis is calculated based on the Left Axis, and consequently ends up off scale at the top, or lined up on top of each other at zero Y value.
Using the CalcPosValue and CalcPosPoint, the correct position can be determined based on whichever Axis (scales) one selects, however, when displaying the DLines, these functions return values that are not within the correct axis domain.
At present, I’m only using the standard Left & Right Axis's, but in the near future, I will be modifying to include multiple Left and Right Custom Axis’s, and I fear this issue may be a problem there also.
Can you assist?
Thanks!
Can you assist?
Thanks!
- DLineTest.Zip
- (3.6 KiB) Downloaded 1192 times
Re: DLine Axis Assignment Reference issue
Hello tirby,
I've changed your code for this and it seems to work fine for me here. I only take the the values in the line relative to the right axis scale, calculated the pixels they correspond to, calculated the values relative to the left axis that correspond to these pixel values, and then added the DLine so it is now relative to the left axis scale:
I think you only missed to force a chart redraw before using these functions.tirby wrote:Using the CalcPosValue and CalcPosPoint, the correct position can be determined based on whichever Axis (scales) one selects, however, when displaying the DLines, these functions return values that are not within the correct axis domain.
'DLine relative to the right axis
Dim startYPix, endYPix As Integer
Dim startYVal, endYVal As Double
With TChart1.Axis.Right
startYPix = .CalcYPosValue(12000)
endYPix = .CalcYPosValue(16000)
End With
With TChart1.Axis.Left
startYVal = .CalcPosPoint(startYPix)
endYVal = .CalcPosPoint(endYPix)
End With
With TChart1.Tools.Items(dline(1)).asDrawLine
'.AddLine 620, 12000, 820, 16000
.AddLine 620, startYVal, 820, endYVal
.Pen.Color = vbMagenta
End With
Thanks Yeray,
I added/changed my code using the code you provided.
Now when both Series0 and Series1 are active, I see both DLines.
If I disable only Series1, both DLines remain visible.
If I disable only Series0, both DLines disappear. <<<<<Problem
If I disable both Series, both DLines are visible.
Note that when Series0 is disabled, and Series1 is enabled, both DLines are not visible. I suspect they are simply off scale.
I know I can change the visible property at any time, however, the DLines still need to be in the correct location regardless of whether or not any/either Series is active.
My real project will offer the user the option of selecting up to 8 traces, and can assign either left or right axis to each individual Trace. The user can also select to display any combination of the 8 traces, including all 8. He may well display 1 left Axis, and the remaining Right axis traces, or only left axis plots, or only right axis plots.
Through logic, the visibility of a DLine associated with a specific Trace will be controlled based on the Trace's active property.
All of the above options are subject to the operators discretion, and at any time before and/or after the DLine(s) are created.
Regards...
Regards...
Hi tirby,
All this customization will probably make the usage of the DrawLine tool here more complicate than drawing manually to the canvas.
This should cover the possibilities you describe without having to do further calculations each time the user changes a series visibility or a series axis.
Dim startYPix, endYPix, startXPix, endXPix As Integer
If TChart1.Series(0).Active Then
With TChart1.Series(0)
startXPix = .CalcXPosValue(300)
endXPix = .CalcXPosValue(500)
startYPix = .CalcYPosValue(12)
endYPix = .CalcYPosValue(18)
End With
With TChart1.Canvas
.Pen.Color = vbCyan
.Line startXPix, startYPix, endXPix, endYPix
End With
End If
If TChart1.Series(1).Active Then
With TChart1.Series(1)
startXPix = .CalcXPosValue(620)
endXPix = .CalcXPosValue(820)
End With
With TChart1.Canvas
End With
End If
Yeray,
Yes, Thankyou - That's what I need to happen.
A few questions:
1. How do I get an Index reference to the Line(s) drawn on the canvas?
There will be several Lines associated with each trace at points selected by the user.
2. I need to place a Rectangle at the top end of each of those lines.
Do I still use a Rectangle Tool?
I need to populate it with text as well as control the forecolors and backcolors.
3. How do I reference the top end of the line to the middle (Y) of the bottom of the retangle, now that the lines reside on the canvas?
A few questions:
Yeray,
Over the past several weeks, my posts/questions have all been about how to accomplish one end result. As each aspect of the development revealed it’s issues, I have to incorporate the changes without changing the code that does work. (Sounds easier than it is!)
I’m using Line Series, Rectangle Tool, and since our last communication the Canvas.Line as opposed to the DLine tool.
Please review this write-up and see if in your opinion, I’m utilizing the best approaches and tools for the task at hand.
In reference to posts in this thread, the changes must follow the setups or parameters I've tried to explain in the attached document.
- Graph.Zip
- Contains Screen shots and documentation.
- (154.24 KiB) Downloaded 1260 times
Really looking for an answer to my post dated: 10 Jun 2013 15:43
Can anyone help?
Can anyone help?
Excuse us for the delayed reply here. We haven't forgotten it and we'll study it asap, but note this isn't a punctual doubt that can be reviewed easily.
You may be interested on the ProSupport subscription.
http://steema.com/licensing/support/?st ... ng_support
Hello again,
I've been playing for a while with your application and I think I reached a behaviour similar to what you are trying to achieve.
I ended using Rectangle tools, since they already can show an arrow to any point you wish, in pixels.
I'm using some global arrays to store the start point of the arrows that are actually an index of the series (markStartIndex) and another array to store the position of the rectangle tool. The end point of the arrow is internally calculated, relative to the position of the rectangle tool and the start point of the arrow.
Dim markEndPos(2) As TeePoint2D
Dim markStartIndex(2) As Integer
Dim draggingRect As Integer
Private Sub Command1_Click(Index As Integer)
TChart1.Series(Index).Active = Not TChart1.Series(Index).Active
TChart1.Tools.Items(Index).Active = Not TChart1.Tools.Items(Index).Active
Select Case TChart1.Series(Index).Active
Case False
Label1(Index).Caption = "Disabled"
Case True
Label1(Index).Caption = "Enabled"
End Select
Private Sub Command2_Click(Index As Integer)
With TChart1.Tools.Items(Index).asRectangle
.AllowDrag = Not .AllowDrag
Select Case .AllowDrag
Case True
Label2(Index).Caption = "UnPined"
Case False
Label2(Index).Caption = "Pined"
End Select
End With
Private Sub Form_Load()
Dim dline(2) As Integer
TChart1.Series(0).Title = "My series 0"
TChart1.Series(0).AddXY 0, 0, "", vbBlue
TChart1.Series(0).AddXY 100, 10, "", vbBlue
TChart1.Series(0).AddXY 300, 12, "", vbBlue
TChart1.Series(0).AddXY 600, 8, "", vbBlue
TChart1.Series(0).AddXY 1200, 16, "", vbBlue
TChart1.Series(0).AddXY 3600, 22, "", vbBlue
TChart1.Series(1).Title = "My series 1"
TChart1.Series(1).AddXY 0, 0, "", vbRed
TChart1.Series(1).AddXY 120, 2000, "", vbRed
TChart1.Series(1).AddXY 320, 6000, "", vbRed
TChart1.Series(1).AddXY 620, 12000, "", vbRed
TChart1.Series(1).AddXY 1220, 1000, "", vbRed
TChart1.Series(1).AddXY 3600, 2700, "", vbRed
Label1(0).Caption = "Enabled"
Label1(1).Caption = "Enabled"
Label2(0).Caption = "Pined"
Label2(1).Caption = "UnPined"
TChart1.Tools.Add tcRectangle
With TChart1.Tools.Items(0).asRectangle
.AutoSize = True
.Text = TChart1.Series(0).Title
.AllowResize = False
.AllowDrag = False
.Callout.Arrow.Visible = True
.Callout.Arrow.Color = vbCyan
markStartIndex(0) = 2
markEndPos(0).X = 500
markEndPos(0).Y = 18
End With
With TChart1.Tools.Items(1).asRectangle
.AutoSize = True
.Text = TChart1.Series(1).Title
.AllowDrag = True
.Callout.Arrow.Color = vbMagenta
markStartIndex(1) = 3
markEndPos(1).X = 820
markEndPos(1).Y = 16000
End With
draggingRect = -1
recalcPositions
Private Sub recalcPositions()
TChart1.Repaint
startXPix = .CalcXPos(markStartIndex(0))
endXPix = .CalcXPosValue(markEndPos(0).X)
startYPix = .CalcYPos(markStartIndex(0))
endYPix = .CalcYPosValue(markEndPos(0).Y)
End With
.Callout.XPosition = startXPix
.Callout.YPosition = startYPix
.Left = endXPix
.Top = endYPix
End With
End If
startXPix = .CalcXPos(markStartIndex(1))
endXPix = .CalcXPosValue(markEndPos(1).X)
startYPix = .CalcYPos(markStartIndex(1))
endYPix = .CalcYPosValue(markEndPos(1).Y)
End With
.Left = endXPix
.Top = endYPix
End With
End If
Private Sub TChart1_OnRectangleToolClick(ByVal Button As TeeChart.EMouseButton, ByVal Shift As TeeChart.EShiftState, ByVal X As Long, ByVal Y As Long)
Dim i As Integer
For i = 0 To TChart1.Tools.Count - 1
If TChart1.Tools.Items(i).ToolType = tcRectangle Then
If TChart1.Tools.Items(i).asRectangle.Clicked(X, Y) Then
draggingRect = i
End If
End If
Next i
Private Sub TChart1_OnRectangleToolDragged()
draggingRect = -1
Private Sub TChart1_OnRectangleToolDragging()
If draggingRect > -1 Then
With TChart1.Tools.Items(draggingRect).asRectangle
If TChart1.Series(draggingRect).HorizontalAxis = aBottomAxis Or _
TChart1.Series(draggingRect).HorizontalAxis = aBothHorizAxis Then
markEndPos(draggingRect).X = TChart1.Axis.Bottom.CalcPosPoint(.Left)
Else
If TChart1.Series(draggingRect).HorizontalAxis = aTopAxis Then
markEndPos(draggingRect).X = TChart1.Axis.Top.CalcPosPoint(.Left)
End If
End If
If TChart1.Series(draggingRect).VerticalAxis = aLeftAxis Or _
TChart1.Series(draggingRect).VerticalAxis = aBothVertAxis Then
markEndPos(draggingRect).Y = TChart1.Axis.Left.CalcPosPoint(.Top)
Else
If TChart1.Series(draggingRect).VerticalAxis = aRightAxis Then
markEndPos(draggingRect).Y = TChart1.Axis.Right.CalcPosPoint(.Top)
End If
End If
End With
End If
Private Sub TChart1_OnScroll()
recalcPositions
Private Sub TChart1_OnUndoZoom()
recalcPositions
Private Sub TChart1_OnZoom()
recalcPositions
Yeray,
Thanks for all your help!
I started a new test project using the code you posted on Tuesday, June 18, 2013.
I see that you are using markStartIndex(x) to point to which data point to use in calculating the X-Y for the Rectangle and Arrow.
This method doesn’t work within the parameters of the project.
The user will select a point on the Line that may or may not be on an actual data point.
Example: Using Series1, there are 2 points,
X=620/Y=12000 >>>> 4th Data Point
X=1220/Y=1000 >>>> 5th Data Point
The user may click on the plotted line at X=1000/Y=5000.
This is the exact XY point where the Retangle.Callout.XPosition needs to start at.
The endXPix of the Arrow needs to terminate 20 Pixels to the right of the Retangle.Callout.XPosition
The endYPix of the Arrow needs to terminate -50 pixels above the Rectangle.Callout.YPosition.
At these 2 endpoints is the bottom of the Rectangle tool.
I have tried several combinations of the CalcXPos(), CalcYPos(), CalcXPosValue(), CalcYPosValue(), Left and Right Axis, etc.
None of these functions return the correct Pixel values.
I tried using the TChart1.Environment.InternalRepaint as well with no success.
As I stated above, I have taken the latest code and started a test project.
I have modified it to work the way it needs to work within my actual project.
There are several other issues I need to resolve, but I believe they are related to this issue.
Again, I do appreciate your assistance, and please forgive me my tone of urgency.
I have a lot of work to complete in a very, very short period of time.
Thanks!
Thanks!
- DLineTest1.Zip
- DLineTest1 project & Notes
- (15.69 KiB) Downloaded 1239 times
Excuse me, the code from 18th June was just a modification taking your initial project as base. However, I forgot I also added two buttons and two labels, making necessary to upload the full project again. Here it is:
I will take a look at the new version of the project and the notes you attached on 20th June asap.
In the meanwhile, please take a look at what I did in the project above. As you've noticed, I used markStartIndex() to store the start point of each draw line. Of course this was just an example that may not adjust your needs, but if you understand it I don't think it shouldn't be difficult to adapt it to your needs. Concretely, if you don't want to use markStartIndex storing the series index related to the draw line tool because you don't want such a relation, you can create two arrays (ie markStartPos(2) as TeePoint2D) similar to the markEndPos array I used to store the end positions of the tools.
Yeray,
Thank you for looking at this project/issue.
I downloaded the project you modified with the addition of the 2 buttons and 2 labels.I also reviewed and made the modifications you suggested.
In General:
Added:
In Form_Load(), added:
In recalcPositions():
Added/modified:
In evaluating the results by examining where on the plotted line the Arrow starts, I find it does not start at the points specified in the Form_Load() proceedure. By "Zooming" in you can see that the Y point is several points away from the correct position.
Also, if you try to "Zoom" more than about 3 times, an overflow error occurs.
Graciously awaiting your reply...
In General:
Added:
Dim markStartPos(2) As TeePoint2D
markStartPos(0).X = 700
markStartPos(0).Y = 9.345
Added/modified:
startXPix = .CalcXPosValue(markStartPos(0).X) '.CalcXPos(markStartIndex(0))
startYPix = .CalcYPosValue(markStartPos(0).Y) '.CalcYPos(markStartIndex(0))
TeePoint2D is an (X,Y) pair of Integer. That's why there seems to be a rounding problem. I've changed:
For:
And it works fine now. Note I've also changed the usages of markStartPos(0).X for markStartPos(0, 0), markStartPos(0).Y for markStartPos(0, 1), etc
Dim markStartPos(2, 2) As Double
Dim markEndPos(2, 2) As Double
Yeray,
Thanks so much! That solved the problem.
And as for the "Overflow" error when zooming - In recalcPositions(),
I changed the 4 startX-Y, endX-Y from integers to doubles.
Thanks again!
Thanks again!
