Are there only 10 pointer styles?
If so, where can I find a list?
Is it possible to design our own pointer styles to use?
If so, where can I find an example or directions?
Line chart pointer styles
Re: Line chart pointer styles
The pointer styles are: "rectangle", "cube", "cylinder", "cone", "ellipse", "sphere", "triangle", "diamond", "downtriangle", "cross", "x".
These are the basic pointer styles supported in all the TeeChart versions.
Also, you can assign an image to be used as brush. Ie:
Series1.pointer.format.image.url="./images/metal.jpg";
How can I assign different value based pointer styles to individual points on the graph?
The only way I can think is to override the Pointer.draw function changing the style in it depending on the index.
