Is it possible to define a legend as a grid of Rows and Cols
redgar
Post by redgar » Mon Mar 18, 2013 10:40 am
I am using the latest version of TeeChart Pro 2012 VCL on Delphi XE3.
Is it possible to define a legend as a grid of Rows and Cols. The text is too great and so I have to use a small font which is hard to read. Additionally if the application is resized the legend layout is lost and sprawls poorly across several lines (see images attached)
I was hoping to be able to define row and column headers and just have the appropriate coloured checkbox within; is this possible?
Many thanks in advance
Rob
Resized layout
KPI 2.jpg (382.43 KiB) Viewed 7728 times
Original Layout
KPI 1.jpg (318.4 KiB) Viewed 7771 times
Re: Is it possible to define a legend as a grid of Rows and Cols
Post by Narcís » Mon Mar 18, 2013 12:20 pm
Hi Rob,
I'm not sure about what you mean with this:
Anyway, I'd recommend you to look at the custom legend tool demoed at the What's New?\Welcome!\New Chart Tools\Custom Legend example in the features demo, available at TeeChart's program group or the TChartGrid component at All Features\Welcome\Components\Chart Grid in the same demo.
If this doesn't fit your needs please give us more detailed information about what you are trying to achieve.
redgar
Post by redgar » Mon Mar 18, 2013 2:47 pm
Hi Narcis,
I was hoping to achieve something akin to this
This is what I hoped to achieve as it cuts down on repeated, though necessary text, in the legend.
KPI 3.jpg (35.09 KiB) Viewed 7651 times
redgar
Post by redgar » Tue Mar 19, 2013 10:55 am
As can be seen in the very first image, the legend loses its neat layout with all associated legends no longer in a straight vertical line down (effectively a column), which is represented in the second image.
However there is a lot of repeated text, and I wondered if it was possible to combine a consistent fixed number of rows and columns with the checkbox to switch on graphed datasets.
Please advise if this is possible.
Many thanks
Rob
Post by Yeray » Wed Mar 20, 2013 5:01 pm
Hi Rob,
Have you tried using the TCustomLegendTool as Narcís indicated?
I've made a quite complete example:
  private
    { Private declarations }
    procedure DrawCustomLegend();
    procedure StringGrid1DrawCell(Sender: TObject; ACol, ARow: Integer;
                                  Rect: TRect; State: TGridDrawState);
    procedure ClickTool(Sender:TAnnotationTool; Button:TMouseButton; Shift: TShiftState; X, Y: Integer);
var
  CustomLegendTool : TCustomLegendTool;
  jobs  : Array[0..4] of string = ('Builders', 'Electricians', 'Gardeners', 'Mechanical', 'Painters');
  days  : Array[0..3] of string = ('Within 1 Day', 'Within 3 Day', 'Within 7 Day', 'More than 7 Days');
  colors: Array[0..4] of TColor;
var
  i, j, d: Integer;
  colors[0]:=rgb(226, 108, 10);
  colors[1]:=rgb(49, 133, 157);
  colors[2]:=rgb(118, 147, 57);
  colors[3]:=rgb(149, 54, 52);
  colors[4]:=rgb(128, 128, 128);
  CustomLegendTool := TCustomLegendTool.Create(Chart1);
  DrawCustomLegend();
  for j:=0 to length(jobs)-1 do
    for d:=0 to length(days)-1 do
        Color:=ApplyBright(colors[j], 80-(d*20));
        XValues.DateTime:=true;
        BarStyle := bsBevel;
        Active:=j=1;
        for i:=0 to 3 do
          AddXY(IncMonth(MonthOf(Today), i) , 30 + random*130)
  CustomLegendTool.Height := 120;
  with Chart1 do
    Legend.Visible:=false;
    Title.Visible:=false;
    Axes.Bottom.DateTimeFormat:='MMMM';
    Axes.Bottom.LabelStyle:=talPointValue;
    MarginUnits:=muPixels;
    MarginTop:=CustomLegendTool.Height + 20;
  Chart1.Draw;
  CustomLegendTool.Left := (Chart1.Width div 2) - (CustomLegendTool.Width div 2);
procedure TForm1.DrawCustomLegend();
var i: Integer;
  with CustomLegendTool do
    ParentChart := Chart1;
    AllowDrag:=false;
    AllowResize:=false;
    with Shape do
      RoundSize := 15;
      Pen.Width:= 2;
      Font.Style := [fsItalic];
      ShapeStyle:=fosRectangle;
    Grid.OnDrawCell:=StringGrid1DrawCell;
    OnClick:=ClickTool;
    with Grid do
      ColCount := length(jobs)+1;
      RowCount := length(days)+1;
      for i:=0 to RowCount-1 do
        RowHeights[i] := 20;
      ColWidths[0] := 120;
      for i:=1 to ColCount-1 do
        ColWidths[i] := 80;
      Height := 105;
      Width := 526;
procedure TForm1.StringGrid1DrawCell(Sender: TObject; ACol, ARow: Integer;
var
  seriesIndex: Integer;
  if (ACol = 0) then
    if (ARow > 0) then
      with CustomLegendTool.Grid.Canvas.Font do
      CustomLegendTool.Grid.Canvas.TextRect(Rect, Rect.Left+60, Rect.Top+1, days[ARow-1]);
  end
    if (ARow = 0) then
      CustomLegendTool.Grid.Canvas.TextRect(Rect, Rect.Left+35, Rect.Top+3, jobs[ACol-1]);
    end
      seriesIndex:=(ARow-1) + length(days)*(ACol-1);
      CustomLegendTool.Grid.Canvas.Pen.Style:=psClear;
      CustomLegendTool.Grid.Canvas.Brush.Color:=Chart1[seriesIndex].Color;
      CustomLegendTool.Grid.Canvas.Rectangle(Rect);
      TeeDrawCheckBox(Rect.Left+39, rect.Top+3, CustomLegendTool.Grid.Canvas, Chart1[seriesIndex].Active, clWhite);
      CustomLegendTool.Grid.Canvas.Pen.Style:=psSolid;
      CustomLegendTool.Grid.Canvas.Brush.Color:=clNone;
procedure TForm1.ClickTool(Sender:TAnnotationTool; Button:TMouseButton; Shift: TShiftState; X, Y: Integer);
var seriesIndex, nCol, nRow: Integer;
  with CustomLegendTool.Grid do
    MouseToCell(X-ColWidths[0], Y-RowHeights[0], nCol, nRow);
  if (nCol > 0) and (nCol<CustomLegendTool.Grid.ColCount) and
     (nRow > 0) and (nRow<CustomLegendTool.Grid.RowCount) then
    seriesIndex:=(nRow-1) + length(days)*(nCol-1);
    Chart1[seriesIndex].Active:=not Chart1[seriesIndex].Active;
redgar
Post by redgar » Thu Mar 21, 2013 2:31 pm
:D My word Yeray, I think that is one of the most beautiful things I have ever seen, you should add that to your demos.
I will take your sample code and seek to make the same work in my applications.
Many many thanks
Rob
Post by Yeray » Thu Mar 21, 2013 2:45 pm
Hi Rob,
redgar wrote::D My word Yeray, I think that is one of the most beautiful things I have ever seen, you should add that to your demos.
Thanks for the compliments, but the idea is actually yours :P
We'll take your word and we'll add it to the demos.
