Series Region tool draws outside chart area
christianh
Post by christianh » Fri Mar 08, 2013 11:59 am
I have attached the region tool to a line series. If I move/scroll the series, the region tool draws outside the chart area (within the y-axis area). The lines itself are truncated correctly but the region is drawn outside. This happens on the left and on the right side of the chart. I have the 121105 VCL 32bit build installed.
Any hints?
See the SeriesRegion tool drawing outside of charting area.
08-03-2013 07-00-14.jpg (51.76 KiB) Viewed 7087 times
Re: Series Region tool draws outside chart area
Post by Yeray » Fri Mar 08, 2013 5:14 pm
I've added it to the wish list to be included in future releases (TV52016532).
christianh
Post by christianh » Thu Mar 14, 2013 5:58 pm
I would like to add that this happens also on the vertical axis. See the attached screenshot. Note the scale of the series on the bottom ("Beta") goes from approx. -0.04 to -0.09. The regiontool draws to the 0 value but this is outside of the boundary given for that series axis. It is already in the area which belongs to the middle series ("Change (R)").
14-03-2013 18-52-22.jpg (72.05 KiB) Viewed 7007 times
Post by Yeray » Fri Mar 15, 2013 2:57 pm
Hi Chris,
I've updated the TV52016532 ticket. Now it says:
Clip the TSeriesRegionTool to the rectangle defined by the axes associated to the tool.
I think it covers both cases. Don't hesitate to let us know if you feel it doesn't.
Post by Yeray » Tue Jul 16, 2013 11:10 am
This is just to let you know we've just fixed TV52016532, so it will be included in the next maintenance release.
