DaveSav
Post
by DaveSav » Sun Feb 17, 2013 12:29 am
I have set as many backgrounds as i could find to black; but I can't find how to set the Axis text to white.
Please advise.
- oops.png (4.6 KiB) Viewed 24542 times
Code:
tchart.getPanel().setTransparent(false);
tchart.getPanel().setColor(Color.BLACK);
tchart.getWalls().getBack().setColor(Color.BLACK);
tchart.getWalls().getBack().getGradient().setVisible(false);
tchart.getZoom().setZoomStyle( ZoomStyle.FULLCHART);
Post
by Yeray » Mon Feb 18, 2013 9:05 am
Hi Dave,
Try this to set the axes labels colors:
tchart.getAxes().getLeft().getLabels().getFont().setColor(Color.WHITE);
tchart.getAxes().getBottom().getLabels().getFont().setColor(Color.WHITE);
DaveSav
Post
by DaveSav » Mon Feb 18, 2013 8:52 pm
Thanks, Yeray.
Is there a way to remove the black lines from the area chart, and how can I change the look of the background grid?
Dave
Post
by Yeray » Tue Feb 19, 2013 10:43 am
Hi Dave,
DaveSav wrote:Is there a way to remove the black lines from the area chart
Being area1 an instance of the Area class, to hide the area lines:
area1.getAreaLines().setVisible(false);
DaveSav wrote:how can I change the look of the background grid?
You can personalize the Axes Grid Pens like, ie:
tChart1.getAxes().getLeft().getGrid().setStyle(DashStyle.DOT);
tChart1.getAxes().getBottom().getGrid().setVisible(false);
DaveSav
Post
by DaveSav » Tue Feb 19, 2013 10:01 pm
Thanks Yeray,
It looks like I've set up my Area chart incorrectly:
Series ln = new Area(tchart.getChart());
((Area)ln).getAreaLines().setVisible(false);
((CustomPoint)ln).setStacked(CustomStack.NONE);
[do a loop here]
DateTime dt = new DateTime(blah,blah,blah);
ln.add(dt, double(DurationData.get(i).getDuration /60 /60));
[end loop]
It seems to work ok, but would be nice to instantiate it correctly.
Dave
DaveSav
Post
by DaveSav » Tue Feb 19, 2013 11:20 pm
Now I'm not sure that Area is what I want. Is there a way to shade below the lines of a line chart?
Post
by Yeray » Wed Feb 20, 2013 8:13 am
Hi Dave,
I'm not sure to understand what you mean. Could you please explain it with more details? Adding some image may help too.
DaveSav
Post
by DaveSav » Wed Feb 20, 2013 8:55 pm
Before buying TeeChart, I was using aChartEngine, and you could add a transparent shading below each series line, as in the image below.
- achart.png (51.31 KiB) Viewed 24478 times
Dave
Post
by Yeray » Fri Feb 22, 2013 1:12 pm
Hi Dave,
You can set the transparency to the Area series as here:
Area area1 = new Area(tChart1.getChart());
area1.fillSampleValues();
area1.setTransparency(50);
Or something more similar to your image, with wider lines, blue transparent areas, pointer visible for one of them...
for (int i=0; i<2; i++) {
Area area = new Area(tChart1.getChart());
area.fillSampleValues();
area.getLinePen().setWidth(2);
area.getLinePen().setColor(Theme.OnBlackPalette[i]);
area.setColor(Color.BLUE);
area.getAreaLines().setVisible(false);
area.setTransparency(80);
if (i==0) {
area.getPointer().setVisible(true);
area.getPointer().setStyle(PointerStyle.CIRCLE);
area.getPointer().getBrush().setSolid(false);
area.getPointer().getPen().setColor(area.getLinePen().getColor());
