Lionel Père
Post
by Lionel Père » Fri Feb 15, 2013 11:10 am
I have a problem with some pie, when i have too long and too much labels. The pie is not circular anymore.
What can i do to keep it circular ? I don't mind if it has to be smaller, but i don't want to see something like that (see attachment).
I use the following code to layout my chart :
private void layoutPieChart(TChart chart) {
chart.getPanel().setBorderRound(15);
chart.getPanel().getPen().setColor(new Color(getResources().getColor(R.color.value_neg)));
chart.getPanel().setColor(new Color(getResources().getColor(R.color.white)));
chart.getAspect().setView3D(true);
chart.getHeader().getFont().setColor(new Color(getResources().getColor(R.color.blue_dark)));
chart.getHeader().getFont().setSize(15);
chart.getAspect().setOrthogonal(true);
ColorPalettes.applyPalette(chart.getChart(), TChartUtil.getPalette());
chart.getLegend().setAlignment(LegendAlignment.BOTTOM);
chart.getLegend().getFont().setSize(15);
chart.getLegend().setTextStyle(LegendTextStyle.RIGHTPERCENT);
chart.getLegend().setTransparent(true);
chart.getWalls().getBack().setVisible(false);
chart.getCanvas().setBackColor(new Color(getResources().getColor(R.color.value_neg)));
((com.steema.teechart.styles.Pie) chart.getSeries(0)).setCircled(true);
((com.steema.teechart.styles.Pie) chart.getSeries(0)).getMarks().setVisible(false);
((com.steema.teechart.styles.Pie) chart.getSeries(0)).getPen().setVisible(true);
Thanks for your help.
Lionel
- Screenshot_2013-02-15-12-04-45.jpg (153.22 KiB) Viewed 19153 times
Post
by Yeray » Mon Feb 18, 2013 8:30 am
Hi Lionel,
Are you sure the code you posted produces the chart in the image you attached? I see in the code the lines:
But the pie in the image seems to be 2D and the marks are shown.
Could you please revise it?
Lionel Père
Post
by Lionel Père » Mon Feb 18, 2013 8:39 am
My bad, I paste the wrong code
mTChart = (TChart) rootView.findViewById(R.id.chart);
mTChart.getAspect().setView3D(false);
mTChart.getAspect().setOrthogonal(true);
// mTChart.getPanel().setMarginLeft(20);
mTChart.getPanel().setColor(new Color(getResources().getColor(R.color.white)));
mTChart.getPanel().setBorderRound(10);
// Header
mTChart.getHeader().getFont().setSize(30);
mTChart.getHeader().setText(getString(R.string.pie_chart_perf_year_title));
mTChart.getHeader().getFont().setBold(true);
mTChart.getLegend().setVisible(false);
mTChart.getAxes().setVisible(true);
mTChart.getAxes().setDrawBehind(true);
mTChart.getWalls().setVisible(false);
ColorPalettes.applyPalette(mTChart.getChart(), TChartUtil.getPalette());
mTChart.addSeries(getMasterStats("ECO_SECT_D"));
mTChart.getSeries(0).getMarks().setTransparent(true);
mTChart.getSeries(0).getMarks().getFont().setSize(17);
mTChart.getSeries(0).getMarks().setStyle(MarksStyle.LABELPERCENT);
Post
by Yeray » Mon Feb 18, 2013 3:28 pm
I can't still reproduce it with the following code:
Pie pie1 = new Pie(tChart1.getChart());
pie1.setCircled(true);
Random r = new Random();
for (int i=0; i<20; i++) {
pie1.add(5 + r.nextDouble() * 5, "long point label nº" + String.valueOf(i));
tChart1.getAspect().setOrthogonal(true);
tChart1.getPanel().setColor(Color.WHITE);
tChart1.getPanel().setBorderRound(10);
// Header
tChart1.getHeader().getFont().setSize(30);
tChart1.getHeader().setText("My Title");
tChart1.getHeader().getFont().setBold(true);
tChart1.getHeader().getFont().setColor(Color.BLUE);
tChart1.getAxes().setVisible(true);
tChart1.getAxes().setDrawBehind(true);
tChart1.getWalls().setVisible(false);
ColorPalettes.applyPalette(tChart1.getChart(), 1);
pie1.getMarks().setTransparent(true);
pie1.getMarks().getFont().setSize(17);
pie1.getMarks().setStyle(MarksStyle.LABELPERCENT);
- 2013-02-18_1625.png (85.83 KiB) Viewed 19103 times
There could still be something we are doing different. Are you using SWT or Swing? Are you using the latest TeeChart version (v2012.0808)?
Lionel Père
Post
by Lionel Père » Mon Feb 18, 2013 4:28 pm
I just purchased your product 2 weeks ago.
"Build 3.2012.1120"
Actually, I use the same TChart to produce differents charts. When I select a type of chart, generate his Series with the following method.
private void generateChart(int chartType) {
mTChart.getHeader().setText(getResources().getStringArray(R.array.chart_list)[chartType]);
mTChart.removeAllSeries();
switch (chartType) {
case PIE_ASSET_CAT:
mTChart.addSeries(getAssetCatRepartition());
// mTChart.getLegend().setVisible(true);
// mTChart.getLegend().setTextStyle(LegendTextStyle.RIGHTPERCENT);
// mTChart.getLegend().getFont().setSize(17);
break;
case PIE_CAT_ECO_SECT:
// mTChart.getLegend().getFont().setSize(10);
break;
case PIE_ECO_SECT:
mTChart.addSeries(getDetailStats("ECO_SECT_D"));
break;
case PIE_CONTINENT:
mTChart.addSeries(getMasterStats("COUNTRY"));
break;
case PIE_COUNTRY:
mTChart.addSeries(getDetailStats("COUNTRY"));
break;
case BAR_BONDS_MATURITY_DATE:
mTChart.addSeries(getMaturityDateRepartition());
mTChart.getSeries(0).getMarks().setTransparent(false);
mTChart.getSeries(0).getMarks().setStyle(MarksStyle.VALUE);
mTChart.getSeries(0).getMarks().setBackColor(new Color(getResources().getColor(R.color.blue_light_soft)));
break;
case PIE_CURRENCY:
mTChart.addSeries(getDetailStats("CURRENCY"));
break;
default:
mTChart.getHeader().setText("Error invalid chart selection");
mCurrentChartType = chartType;
Post
by Yeray » Tue Feb 19, 2013 10:10 am
Hello Lionel,
I've checked your code and it gives me circled pies as soon as I add setCirled(true), that doesn't seem to be present in the last snipped of code you've posted.
And I've tried it now with TeeChart Java for Android v2012.1120.
Please, try to simplify your application to the minimum where the problem can still be reproduced. Then, attach the application here in the forums so we can run it as-is and reproduce the problem here.
Lionel Père
Post
by Lionel Père » Tue Feb 19, 2013 10:18 am
I'm stupid ... didn't call setCirled(true) on my Pie() series.
Thank you a lot for your help, everything is now OK !
Great support service.
Lionel
Post
by Yeray » Tue Feb 19, 2013 10:20 am
Hi Lionel,
Agh... well, glad to be helpful and happy to hear you found it.
