Need some help for a simple task!!!
johnnix
Post by johnnix » Tue Nov 13, 2012 8:37 am
Hello all,
I am completely stack with this so I need a fresh look from someone else!!! I created this chart, works as I want to but it looks like I cannot hide one name group, for example I need the user to be able to show/hide Name1 or Name2 etc. Any help please !!!!
Re: Need some help for a simple task!!!
Post by Yeray » Tue Nov 13, 2012 3:24 pm
Hi Johnnix,
Could you please clarify if you want to hide just the "Name2" text, or also the bars above it?
johnnix
Post by johnnix » Wed Nov 14, 2012 7:36 am
I need to hide both label and bars :)
Post by Yeray » Wed Nov 14, 2012 8:44 am
Hi Johnnix,
Then, I'd work with null points. Known the ValueIndex to hide, you can loop all your series and set as null:
    Chart1[i].SetNull(ValueIndex);
Post by Yeray » Wed Nov 14, 2012 9:03 am
Hi again,
In addition to the above, when I tried the following code, where I have 5 TBarSeries with 5 values each and I want to hide the ValueIndex=2:
uses Series;
var i, j, ValueIndex: Integer;
  Chart1.View3D:=false;
  for i:=0 to 4 do
    with Chart1.AddSeries(TBarSeries) do
      FillSampleValues(5);
      Marks.Visible:=false;
      for j:=0 to Chart1[i].Count-1 do
        Chart1[i].Labels.Labels[j]:='Name'+IntToStr(j+1);
  ValueIndex:=2;  //ValueIndex to hide
I've seen the bars with ValueIndex=2 are correctly hidden, but not the bottom axis label.
However, you can always hide those labels in the bottom axis with no visible value associated:
procedure TForm1.Chart1GetAxisLabel(Sender: TChartAxis;
  Series: TChartSeries; ValueIndex: Integer; var LabelText: String);
var i: Integer;
  if (Sender=Chart1.Axes.Bottom) and (ValueIndex>-1) then
      if Chart1[i].IsNull(ValueIndex) then
        if i=Chart1.SeriesCount-1 then
          LabelText:='';
      end
        exit;
And the above seems to work fine for me here.
johnnix
Post by johnnix » Thu Nov 15, 2012 7:41 am
Hello Yeray,
Thank you very much for the prompt reply, I will give it a try !!!
Kindest regards
