Issue when rotate 2D pie chart using GDI+ canvas
marder
Post by marder » Wed May 09, 2012 12:33 pm
Hi.
I am using TeeChart Pro 2011 for RAD XE2.
As a workaround for a bug with the anti-alias tool I am using TGDIPlusCanvas for canvas of my chart.
This was the suggested workaround (See http://www.teechart.net/support/viewtop ... f=3&t=9180).
I do now encounter an issue when rotating a 2D pie chart.
While rotating one slice disappears and the color of the other slice change.
Please find a sample project attached ("Test2DPieRotate.zip").
just build and run the project and use the mouse wheel to rotate the pie chart.
Please let me know how I can fix this issue.
Thanks for your help!
Test2DPieRotate.zip
(81.84 KiB) Downloaded 1009 times
Re: Issue when rotate 2D pie chart using GDI+ canvas
Post by Yeray » Wed May 09, 2012 2:45 pm
Hi Marder,
You are right, I could reproduce it so I've added it to the defect list to be revised (TV52016180).
At the same time, I've seen the following gives a chart that looks almost if not exactly equal to the original and doesn't produce the wrong behaviour:
  Chart1.View3D:=true;
  Chart1.Chart3DPercent:=1;
  Chart1.Aspect.Elevation:=360;
marder
Post by marder » Fri May 11, 2012 9:49 am
We recently tried to remove this workaround, as you can see in here: http://www.teechart.net/support/viewtop ... =3&t=9180)
Using a "Chart3DPercent" of "1" leads to a very small 3D effect, which is getting worse when increasing the size of the chart (See attachment "Pie2DIssue.png")
In former version of TeeChart Pro you could at lease use a "Chart3DPercent" value of "0", which prevented this effect.
Do you have any idea/workaround for us to prevent this?
Pie chart 2D issue
Post by Yeray » Fri May 11, 2012 12:19 pm
Hi Marder,
I'm afraid I can't think on another workaround at this moment.
marder
Post by marder » Thu Nov 08, 2012 8:46 am
Hi.
I wonder if there might be a fix for this issue in the official release of the upcoming V2012.07?
I would really need to present our customers a good looking 2D pie chart. The provided workaround is not really pretty.
I not, could you think of any other workaround to get a well looking antialias 2D pie chart, without this rotating issue?
Best regards.
Post by Yeray » Thu Nov 08, 2012 5:02 pm
Hi Marder,
marder wrote:I wonder if there might be a fix for this issue in the official release of the upcoming V2012.07?
I'm afraid TeeChart v2012.07 has already been published with no news update relating to this. I see this has been like this since GDI+ was initially supported in TeeChart VCL (v8).
marder
Post by marder » Fri Nov 09, 2012 12:50 pm
Ok, thanks for the feedback!
It it likely, that this will be fixed in the next official release?
Another solution for use would be, that the Antialias tool will be fixed for 2D pie charts (see: http://www.teechart.net/support/viewtop ... f=3&t=9135), since we could then swithc back to the "normal" canvas.
Best regards.
Post by Narcís » Tue Nov 13, 2012 12:37 pm
Hello Marder,
Ok, I have increased the priority of TV52016180 and TV52013798 so they are top-priority issues.
marder
Post by marder » Tue Nov 13, 2012 4:31 pm
Hi Narcis.
Ok, thank you for your help!
Best regards.
