Bar Graph label wrapping
On the sample bar graph, bars 3 and 7 have no labels, the labels are being added correctly,as if I shorten the text hey appear, it is trying to add Aug '10 (N) and Aug '11 (N)
I am guessing the sofware is thinking the will not fit, is there a way of making it wrap?
- Graph.JPG (53.42 KiB) Viewed 8183 times
Re: Bar Graph label wrapping
Hello mikethelad,
I have made a simple code with last version, and I can not reproduce this problem using the code:
Can you please, modify my code because we can reproduce your problem here?
Steema.TeeChart.Styles.Line line;
Steema.TeeChart.Styles.Bar bar1;
Steema.TeeChart.Functions.ExpAverage average1;
DateTime dt = DateTime.Now;
//tChart1.Dock = DockStyle.Fill;
line = new Steema.TeeChart.Styles.Line(tChart1);
bar1 = new Steema.TeeChart.Styles.Bar(tChart1);
average1 = new Steema.TeeChart.Functions.ExpAverage();
bar1.XValues.DateTime = true;
bar1.Marks.Visible = false;
Random rnd = new Random();
for (int i = 0; i < 10; i++)
bar1.Add(dt, rnd.Next(100));
dt = dt.AddMonths(1);
bar1.Color = Color.Green;
bar1.Pen.Color = Color.Green;
line.DataSource = bar1;
line.Function = average1;
line.Color = Color.Gold;
line.LinePen.Width = 3;
tChart1.Axes.Bottom.Labels.DateTimeFormat = "MMM-dd";
tChart1.Axes.Left.Labels.Style = Steema.TeeChart.AxisLabelStyle.PointValue;
for (int i = 0; i < bar1.Count; i++)
if (i == 0)
tChart1.Axes.Bottom.Labels.Items.Add(bar1.XValues[i], DateTime.FromOADate(bar1.XValues[i]).ToString("MMM" + "dd" + "(N)"));
tChart1.Axes.Bottom.Labels.Items.Add(bar1.XValues[i], DateTime.FromOADate(bar1.XValues[i]).ToString("MMM" + "dd"));
I copied your code into a test program, this did not wrap, if I had extra text next to dates which I need sometimes, again it does not wrap but overlaps, I need to wrap to another line below
- Graph.JPG (49.48 KiB) Viewed 8102 times
Hello mikethelad,
Ok. I have modified the code and I suggest you do something as next:
Can you please, tell us if previous code works in your end?
line = new Steema.TeeChart.Styles.Line(tChart1.Chart);
bar1 = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
if(i==0)
bar1.Add(dt, rnd.Next(100),dt.ToString("MMM" + "dd")+ " (N)");
else if(i!=3 && i!=7)
bar1.Add(dt, rnd.Next(100),dt.ToString("MMM" + "dd")+ " index:"+i.ToString());
bar1.Add(dt, rnd.Next(100), dt.ToString("MMM"+"dd")+" (N)");
WrapLabels(bar1);
private void WrapLabels(Steema.TeeChart.Styles.Bar bar)
int maxHeight = 10;
int tmpHeight;
bar1.Labels[i] = bar1.Labels[i].Replace(" ", "\n");
tmpHeight = (int)tChart1.Graphics3D.TextHeight(bar1.Labels[i]);
if (tmpHeight > maxHeight) maxHeight = tmpHeight;
Can't get this to work, I see what you are trying to do, you set
Does something not need to set a steema object ot the maxHeight?
Hello mikethelad,
Sorry, I have forgotten to remove lines of code, aren't useable. Therefore, next line of code must be remove
About your problem, you have some options to achieve solve your problem:
First, is a solution that suggest to you Narcís in this thread, concretely you can find solution in next link. Are you looking it?
If previous solution don't help you, you can use custom labels as I suggest in my first answer. It option overlap the labels and to prevent it you can do something as next code:
Is possible you can adjust the conditions of previous code if you want it works exactly in your end. Moreover, you can consult the next thread where suggest many ways to solve the problem of overlap with custom labels.
My last suggestion is use my previous code where I have added the labels directly in the Series. I have added my code modified to work in correct way:
Can you please, check if previous codes work as you want?
If you have any problems please let me know.
Steema.TeeChart.AxisLabelsItems axislabelItems;
AddCustomLabels();
tChart1.AfterDraw += new PaintChartEventHandler(tChart1_AfterDraw);
tChart1.UndoneZoom += new EventHandler(tChart1_UndoneZoom);
tChart1.Draw();
void tChart1_UndoneZoom(object sender, EventArgs e)
tChart1.Axes.Bottom.Labels.Items.Add(axislabelItems[i]);
tChart1.Draw();
tChart1.Axes.Bottom.Labels.Items[i].Text = tChart1.Axes.Bottom.Labels.Items[i].Text.Replace(" ", "\n");
Steema.TeeChart.AxisLabelItem CurrentLabel, PreviousLabel;
for (int i = 1; i <= tChart1.Axes.Bottom.Labels.Items.Count-1 ; ++i)
CurrentLabel = tChart1.Axes.Bottom.Labels.Items[i];
PreviousLabel = tChart1.Axes.Bottom.Labels.Items[i - 1];
if (CurrentLabel.Left + CurrentLabel.Text.Length== PreviousLabel.Right)
CurrentLabel.Visible = false;
WrapLabels(bar1);
private void AddCustomLabels()
axislabelItems = new AxisLabelsItems(tChart1.Axes.Bottom);
for(int i=0; i<bar1.Count; i++)
if(i==0)
tChart1.Axes.Bottom.Labels.Items.Add(bar1.XValues[i], DateTime.FromOADate(bar1.XValues[i]).ToString("MMM" + "dd" + " (N)"));
axislabelItems.Add(bar1.XValues[i], DateTime.FromOADate(bar1.XValues[i]).ToString("MMM" + "dd" + " (N)"));
axislabelItems.Add(bar1.XValues[i], DateTime.FromOADate(bar1.XValues[i]).ToString("MMM" + "dd"));
if (i == 0)
bar1.Add(dt, rnd.Next(100), dt.ToString("MMM" + "dd") + " (N)");
else if (i != 3 && i != 7)
bar1.Add(dt, rnd.Next(100), dt.ToString("MMM" + "dd") + " index:" + i.ToString());
WrapLabels(bar1);
Getting there thanks, see new sample, how can I move the
WebChart1.Chart.Axes.Bottom.Title.Text = "Problem score (lower problem scores reflect better performance)";
Further down
Further down
- Graph.JPG (50.81 KiB) Viewed 8050 times
Hello mikethelad,
I am afraid the titles of axes can not move independently. For this reason, I suggest you draw directly in the canvas the text of titles of axes as do in next sample of code:
Can you tell us if previous code works as you want?
Steema.TeeChart.Chart tChart1;
protected void Page_Load(object sender, EventArgs e)
Steema.TeeChart.Styles.Line line1 = new Line(WebChart3.Chart);
tChart1 = WebChart3.Chart;
for (int i = 0; i < 10; i )
line1.Add(dt, rnd.Next(100), dt.ToString("MMM -" "dd-" "\nyyyy"));
WebChart3.Chart.Axes.Bottom.Labels.DateTimeFormat = "MMM-dd-yyyy";
// WebChart3.Chart.Axes.Bottom.Labels.Angle = 90;
WebChart3.Chart.Axes.Bottom.Labels.Style = AxisLabelStyle.Text;
WebChart3.Chart.Panel.MarginUnits = PanelMarginUnits.Pixels;
WebChart3.Chart.Panel.MarginBottom = 50;
WebChart3.AfterDraw = new PaintChartEventHandler(WebChart3_AfterDraw);
void WebChart3_AfterDraw(object sender, Graphics3D g)
g.TextAlign = StringAlignment.Near;
g.TextOut((int)tChart1.Axes.Bottom.IStartPos, (int)tChart1.Axes.Left.IEndPos (int)tChart1.Panel.MarginBottom, "Problem score (lower problem scores reflect better performance)");
