Running on Windows 8
Seth
Post by Seth » Fri Oct 05, 2012 6:36 am
Hi.
I'm using your component to development application, and I want to run it on windows 8 (especailly RT).
If I purchase other component, It can run on windows 8 (or Windows 8 RT / Metro IE) ?
I will be looking forward to your reply.
e-mail : jskim@m2soft.co.kr
Re: Running on Windows 8
Post by Yeray » Fri Oct 05, 2012 11:10 am
Hi Seth,
We've just tried it and it seems to work without problems in a Windows 8 laptop.
It just gives you a warning when running the installer:
Clicking on "More info":
Run anyway.png (8.24 KiB) Viewed 5907 times
Clicking on the "Run anyway" button you'll be able to install it normally.
It would be helpful if you could try the evaluation version in your Windows RT and confirm us it works as described above.
