3D Pie
3D Pie
Is it possible to increase the tilt of the 3D Pie?
Re: 3D Pie
Hello mikethelad,
Is possible increase the size of Title of 3D Pie, you need only change the font size as do in next line of code:
tChart1.Title.Font.Size = 15;
Re: 3D Pie
No, I meant the angle on the pie, see sample file, the top is what I am getting from Steema, the bottom one is what is required,
- graph.JPG (27.49 KiB) Viewed 7724 times
Re: 3D Pie
Hello Mikethelad,
Sorry , I got confused. In your case you, first you must change Chart3D as do in next line of code:
If previous line of code doesn't solve your problem you can change the Orthogonal angle as do in next lines of code:
If you have any problems please let me know.
tChart1.Aspect.Chart3DPercent = 40;
tChart1.Aspect.Orthogonal = true;
tChart1.Aspect.OrthoAngle = 30;
Re: 3D Pie
Have tried both of these ways and neither change the pie
Re: 3D Pie
Hello mikethelad,
Ok. Please check next code if works in your end?
Steema.TeeChart.Chart tChart1;
protected void Page_Load(object sender, EventArgs e)
tChart1 = WebChart3.Chart;
private Steema.TeeChart.Styles.Pie pie1;
pie1 = new Pie(tChart1);
//tChart1.Aspect.Orthogonal = true; //uncomment if you want work with Orthogonal property.
//tChart1.Aspect.OrthoAngle = 30;//uncomment if you want works with a Orthogonal property and a determinate angle
pie1.FillSampleValues();
Re: 3D Pie
Work out why and the Chart3DPercent now works thanks
Re: 3D Pie
Hello mikethelad,
I am glad your problem have been solved.
