WPF TeeChart with ElementHost
MVUser6
Post by MVUser6 » Wed Aug 15, 2012 7:37 am
i have WPF teechart control inside an ElementHost(in winforms application).
i want the TeeChart to invoke the AfterDraw event.
i tried to use DoInvalidate,Invalidate,InvalidateVisual, ... and ElementHost.Referesh, ElementHost.Invalidate... , but i can't make the event invoke.
When does the afterdraw event occur and how can i make it invoke inside an ElementHost?
Re: WPF TeeChart with ElementHost
Post by Sandra » Thu Aug 16, 2012 8:33 am
Hello MVUser6,
Can you please try to arrange a simple code because we can reproduce your problem here? On the other hand, you can try use Bitmap in winforms or BitmapSource in WPF to repaint as do in next lines of code:
Bitmap bmp = tChart1.Chart.Bitmap();
or
BitmapSource bmp = tChart1.Chart.Bitmap();
MVUser6
Post by MVUser6 » Thu Aug 16, 2012 10:36 am
Here is a sample project.
i want to somehow make the teechart call the afterdraw, with function call from the elementhost\the teechart itself.
TeeChartTestWithElementHost.rar
(14.46 KiB) Downloaded 516 times
Post by Sandra » Thu Aug 16, 2012 1:39 pm
Hello MVUser6,
If you want TeeChart call AfterDraw Event, you must use the BitmapSource to achieve the Chart draw again. BitmapSource is behaved as bitmap and method Draw() of winforms. I have modified your button click event because the chart is repainted.
        private Steema.TeeChart.WPF.TChart TChartControl;
            InitTChartProperties();
        private void InitTChartProperties()
            this.SuspendLayout();
            TChartControl = new Steema.TeeChart.WPF.TChart();
            elementHost1.Visible = false;
            this.pictureBox1.Controls.Add(this.elementHost1);
            this.TChartControl.Aspect.View3D = false;
            this.elementHost1.BackColor = System.Drawing.Color.Transparent;
            this.elementHost1.Size = new System.Drawing.Size(916, 474);
            this.TChartControl.TabIndex = 3;
             Steema.TeeChart.WPF.Styles.Line line = new Steema.TeeChart.WPF.Styles.Line(TChartControl.Chart);
            this.TChartControl[0].FillSampleValues();
            this.TChartControl.AfterDraw  = new Steema.TeeChart.WPF.PaintChartEventHandler(TChartControl_AfterDraw);
            elementHost1.Child = TChartControl;
            elementHost1.Dock = DockStyle.Fill;
            this.ResumeLayout();
            elementHost1.Visible = true;
        void TChartControl_AfterDraw(object sender, Steema.TeeChart.WPF.Drawing.Graphics3D g)
            richTextBox1.Text  = "AfterDraw Invoked"   Environment.NewLine;
            elementHost1.Refresh();
            BitmapSource bitmap = TChartControl.Chart.Bitmap();
Does it work as you expect?
