Axis Breaks and corrupt axis labels
Philipp P.
Post by Philipp P. » Mon Jul 16, 2012 1:50 pm
I am using the AxisBreak tool to mask out certain areas of my chart on the x-axis using multiple axis breaks, each with GapSize = 30. In most cases the axis breaks mess up my x-axis labels and it seems that multiple labels get overdrawn then (see image attachment)... Is there any way to avoid this?
Thanks in advance
Philipp
overlapping labels.png (91.62 KiB) Viewed 4864 times
Re: Axis Breaks and corrupt axis labels
Post by Narcís » Mon Jul 16, 2012 1:57 pm
Hi Philipp,
Can you please attach a simple example project we can run "as-is" to reproduce the problem here? A general option could be using custom axis labels as in the All Features\Welcome !\Axes\Labels\Custom labels example at the features demo available at TeeChart's program group.
Philipp P.
Post by Philipp P. » Wed Jul 18, 2012 12:05 pm
Hi Narcís,
The problem occurs with different gapsizes and x-axis ranges... I could reproduce the problem with the following small sample application:
[MainForm.Designer.cs]
namespace GuiTestbench
  partial class MainForm
    /// <summary>
    /// Required designer variable.
    /// </summary>
    private System.ComponentModel.IContainer components = null;
    /// <summary>
    /// Clean up any resources being used.
    /// </summary>
    /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
    protected override void Dispose(bool disposing)
      if (disposing && (components != null))
        components.Dispose();
      base.Dispose(disposing);
    #region Windows Form Designer generated code
    /// <summary>
    /// Required method for Designer support - do not modify
    /// the contents of this method with the code editor.
    /// </summary>
    private void InitializeComponent()
      this.tChart1 = new Steema.TeeChart.TChart();
      this.fastLine1 = new Steema.TeeChart.Styles.FastLine();
      this.axisBreaksTool = new Steema.TeeChart.Tools.AxisBreaksTool();
      this.SuspendLayout();
      // tChart1
      this.tChart1.Axes.Depth.LabelsAsSeriesTitles = true;
      this.tChart1.Axes.DepthTop.LabelsAsSeriesTitles = true;
      this.tChart1.Dock = System.Windows.Forms.DockStyle.Fill;
      this.tChart1.Location = new System.Drawing.Point(0, 0);
      this.tChart1.Name = "tChart1";
      this.tChart1.Series.Add(this.fastLine1);
      this.tChart1.Size = new System.Drawing.Size(886, 465);
      this.tChart1.TabIndex = 0;
      this.tChart1.Tools.Add(this.axisBreaksTool);
      // fastLine1
      this.fastLine1.Color = System.Drawing.Color.FromArgb(((int)(((byte)(68)))), ((int)(((byte)(102)))), ((int)(((byte)(163)))));
      this.fastLine1.ColorEach = false;
      this.fastLine1.LinePen.Color = System.Drawing.Color.FromArgb(((int)(((byte)(68)))), ((int)(((byte)(102)))), ((int)(((byte)(163)))));
      this.fastLine1.Title = "fastLine1";
      this.fastLine1.TreatNulls = Steema.TeeChart.Styles.TreatNullsStyle.Ignore;
      this.fastLine1.XValues.Order = Steema.TeeChart.Styles.ValueListOrder.Ascending;
      // axisBreaksTool
      this.axisBreaksTool.Axis = this.tChart1.Axes.Bottom;
      this.axisBreaksTool.GapSize = 5;
      this.axisBreaksTool.ScaleAdjustment = 1E-07D;
      // MainForm
      this.ClientSize = new System.Drawing.Size(886, 465);
      this.Controls.Add(this.tChart1);
      this.Name = "MainForm";
      this.Load += new System.EventHandler(this.MainForm_Load);
      this.ResumeLayout(false);
    #endregion
    private Steema.TeeChart.TChart tChart1;
    private Steema.TeeChart.Styles.FastLine fastLine1;
    private Steema.TeeChart.Tools.AxisBreaksTool axisBreaksTool;
[MainForm.cs]
using System;
using System.Windows.Forms;
using Steema.TeeChart.Tools;
  public partial class MainForm : Form
    public MainForm()
    private void MainForm_Load(object sender, EventArgs e)
      fastLine1.FillSampleValues();
      var axisBreak = new AxisBreak(axisBreaksTool)
        Enabled = true,
        StartValue = 8,
        EndValue = 10,
        Style = AxisBreakStyle.Line
Post by Sandra » Thu Jul 19, 2012 2:17 pm
Hello Pilipp P.
The problem of overlaping of AxisBreaks can be solved of many ways,e.g:
1.- Changing the size of GapSize, adapting it to your labels space.
2.- Changing the scale of Axes.
3.- Changing the angle of labels.
4.- Using custom labels, etc.
Basically, you need treat this problem as you treat anyone of problems to overlap as do in this thread.
