I am using C # is.
I refer to Map GIS example is under development.
Editing dialog open, Series0, Format, Shapes, Points in order to choose.
Here X, Y values can be modified.
However, the source points X, Y do not know how to modify the value.
I try to write the source code to modify the value is.
In addition, I have the ability to delete an item, I want to implement.
Editing dialog like to use the Button.
Modify the map coordinates
- MapEdit
- MapEdit.jpg (77.69 KiB) Viewed 3113 times
Re: Modify the map coordinates
Hello prisol,
Can you tell what version of TeeChart are you using? And in what product you can see this property(VCL,ACTIVEX,Java)?
